-   Skater (https://www.offshoreonly.com/forums/skater-42/)
-   -   308 Classic Outboard Skater (https://www.offshoreonly.com/forums/skater/283279-308-classic-outboard-skater.html)
ryder638 09-17-2012 06:28 PM
there was a pic posted a few years back with a 308 sitting next a 28 at skater and it dwarfed the 28. is there any other pics like that around??
Catastrophe 09-17-2012 07:30 PM
What speeds will be expected with max hp motors ?
What outboards are recommended for these boats.
Approx. retail price with a trailer ????
Maritime_Eng 09-17-2012 08:02 PM
(2) 300xs's and should run 101 to 103 ish and great on fuel. Franks runs well and is a FMO member. Im sure he would give you a ride.
Cavanti53 09-17-2012 08:21 PM
Originally Posted by blume (Post 3778402)
A 338 is being built now with 2 Cadillac SuperCharged motors, ADS 7 drives. It will be close on weight.
Here is info on a 30' Inboard:
GENERAL SPECIFICATIONS
LENGTH 30' 7"
BEAM 9' 4"
HEIGHT 56"
WEIGHT - INBOARD PLEASURE 3200 LBS
FUEL CAPACITY 160 GALLONS
SPONSON DEADRISE 18 DEGREES
CONSTRUCTION HAND LAY-UP
ENGINE CONFIGURATION V-8 INBOARDS (CUSTOM)
Hey Blume,
Any other new Skater projects that you can update us with progress pics on?
I like seeing the progression of the build, paint, etc...
Thank you!
Catastrophe 09-17-2012 08:22 PM
Is that same hull as Franks ?
with 350s its 110 115 ?
Is Franks that wide ??
blume 09-17-2012 08:23 PM
Originally Posted by Cavanti53 (Post 3778738)
Hey Blume,
Thank you!
Got some new pics just need to get them on with info.
Maritime_Eng 09-17-2012 08:34 PM
Im 90% sure its the same as Franks. 350's wont run well becasue the gear case is not ment to be surfaced like a sportmaters on the 300xs. Also on the 300xs the mid section is different a little more surable. Not saying it cant be done but I wouldnt recomend it. They run so well with 300xs's why mess with it.
Catastrophe 09-17-2012 08:41 PM
Gotcha
Had a 32 Skater with 3 300s but was in the day that the tanks were failing . Azzpain.
Put bladders in but by then I was so Pizzed off that I got rid of it for my 43 Nortech.
But it ran great. Loved it.
The ones in Blumes pics are gorgeous.
Catastrophe 09-17-2012 08:53 PM
Anyone got round numbers for 2 300s ??
skate 09-17-2012 08:58 PM
16.5K each more or less
