Boat Custom's 308 Skater OB Flat Deck Conversion. >
Old 11-22-2016 | 08:29 AM
  #411
Originally Posted by Taboma
Sam, Why are you quitting so early? Just kidding! How many other Skater owners drain their tanks for winter?
I always try and run all my boats empty before they sit for 3-4 months. Gasoline loses octane over time when it is vented, so whatever gas is left in the tanks will have a low octane rating by the time the boats get used again. When there's only a few gallons left in the tanks, you can just fill them with fresh fuel and you're good to go on the first trip out after Winter. It has nothing to do with what is good for the tanks or not.
Skater30 is offline
Old 11-22-2016 | 10:05 AM
  #412
Only the poor ones who cannot go boating!!!!!!!
Double Rigged is offline
Old 11-22-2016 | 10:33 AM
  #413
Nice Pair's Avatar
With the 300XS's every time I get near empty the sun comes out for a couple days and I fill them back up. Guess I'll have to boat all winter. ;-)
Nice Pair is offline
Old 11-22-2016 | 11:02 AM
  #414
Thanks, Dale. I was asking just to be cautious because of all the hoopla over tank issues. I use only 91 RM/2 octane premium and just for the reason you stated above, add 100 LL av gas which samples out usually 110 octane according to the local aviation FOB vender as a precaution from old gas. I hope to do some late fall/early spring Skater boating when we have those "I wish I was out in the boat days!" other than in my cruiser with my wife drinking wine and watching the eagles fly - not bad either!
Taboma is offline
Old 11-22-2016 | 12:39 PM
  #415
I run 91 and 93 nonethanol exclusively. I always drain tanks in the winter. I don't like to run old gas not to mention I want to play it safe on the tanks.
My mechanic here has replaced a lot of fuel system parts on several newer outboard brands due to corrosion which he contributes to water contaminated ethanol.
David if it's nice out I know where the gas station is!
skate is offline
Old 11-22-2016 | 03:46 PM
  #416
Always drain tanks !!! Boat will sit for 4 months , not worth the risk of popping a power head when spring
Comes around !
tom kennedy is offline
Old 11-22-2016 | 04:22 PM
  #417
dumb question - how do you drain tanks? I need to.
Orthobam is offline
Old 11-22-2016 | 04:28 PM
  #418
Run the boat Or pump them out
mikebrls is offline
Old 11-22-2016 | 05:28 PM
  #419
Is this a pump you buy at an autozone?
Orthobam is offline
Old 11-22-2016 | 05:36 PM
  #420
Yes, if you want to catch on fire! Unless it is a manual gasoline pump. No, needs to be very specific for gasoline if electric. Just open the NTP plug and siphon out the gas. Trouble is getting a large enough container to "contain" the amount of fuel in the tanks without being too tall to allow gravity to work.
Taboma is offline
