Tanks Skater... >
Tanks Skater...
Tanks Skater...
Old 02-01-2016 | 08:23 PM
  #51
The deeper water ramp idea was bouncing around in my head for awile
I am glad I went that route, they worked great ! I am sure I will go that way on the 28 also
tom kennedy is offline
Old 02-02-2016 | 07:44 PM
  #52
Zero Patience's Avatar
I will test it Saturday, if water pressure is an issue, I do have a file, some west systems epoxy, and paint.
Zero Patience is offline
Old 02-02-2016 | 08:08 PM
  #53
I cut mine with 40 grit paper with sticky back on a 1" pvc pipe. Cut like butter.
Double Rigged is offline
Old 02-03-2016 | 10:21 AM
  #54
Any idea how "thick" the hull is at the ramp area? Ron, your ramps are pretty deep!
Taboma is offline
Old 02-03-2016 | 10:23 AM
  #55
Tom, What were the results of the deeper ramps, i.e., how much higher were you able to go with the cases and with what pressures?
Taboma is offline
Old 02-06-2016 | 03:01 PM
  #56
Rainy, windy, cold, ran it anyway. Water pressure is now 23 psi up from the 12-14 I had. That is at 1 7/8" up. The ramps work very well. I will try it a little higher as I run 15" diameter Dewald.
Old 02-22-2016 | 10:33 PM
  #57
Nice Pair's Avatar
I looked at mine thru the drain plug holes (fittings and bezels are out) I would guesstimate bottom thickness to be 3/4" @ the very back tapering down to 1/2" @ the front of the ramp.
My math says with the 1/4" to 0" ramp > 1/2" +/- left @ the rear and 1/2" +/- @ the front of the ramp. (appears to be solid glass, no core material in that area)
Nice Pair is offline
Old 02-23-2016 | 09:32 AM
  #58
Thanks, Exactly what information I was needing!
Taboma is offline
Old 02-23-2016 | 10:38 AM
  #59
You could just drill some test holes
skate is offline
Old 02-23-2016 | 11:25 AM
  #60
What size do you think are appropriate?
Taboma is offline
