Skater 32a vs 32b
Off hand I know the front sponson design was changed and is the easiest way to spot the difference, the B's extend farther forward before they angle up to the bow. I believe the B's are also a tad wider but not sure how much and if that difference is in the tunnel or the sponsons, I believe it's the sponsons to be able to handle the weight of the I/O setup that became more popular on them. I think most of the A boat's are outboard and most of the B's are inboard. The A's are a little faster with the same power but because the sponsons are longer the B's handle rough water a little better due to the waterline. You could get the B's with 1/4 canopies but I've never seen an A with them at least not from the factory.
Would also like to know more about the delta's. I know there's people here that can tell you every difference, hopefully one of them checks in. It seems participation here has been pretty slow lately.
