Go Back  Offshoreonly.com > Owners Forum > Sonic
small honda generator >
Old 07-09-2005 | 07:42 AM
Default small honda generator
Has anyone ever strapped one of the small honda generators in the engine compartment to run auxiliary stuff?
sonicator is offline
Old 07-09-2005 | 08:09 AM
Default Re: small honda generator
Not a good idea, as the fumes will end up the cabin area, and you'll be a statistic the next morning ! Dont do it.
Strap it on the swim platform when in use.... bungee cords or docklines. Lots of guys I know use the EU2000 with great success for overnighting & runs everything from the AC ( after its been started and running, as starting really draws alot initially ) to the bat charger & microwave all at once ! It runs all night on one tank of gas and its super quiet
Gofastboater45 is offline
Old 07-09-2005 | 08:39 AM
East Coast B's Avatar
There was a discussion recently on this same topic and as GFB45 states, fumes is an issue although you could probably pipe it out without too much trouble. The big issue that someone brought up caught my attention and that is with the generator not being rated for marine use which means it's not equiped for nonspark safety... my buddy runs it off the swimdeck as well... Having the generator in the engine compartment is a great idea, just not a safe one.
You would need an air tight compartment to separate it from the engine room to avoid fumes, then you have to vent it out, but you would still need to have air from somewhere to support the generator and cool it...
Be safe and good luck!!
East Coast B is offline
Old 07-09-2005 | 09:39 AM
Thanks didn't think about them not being marine rated. On the swim platform it goes
Old 07-09-2005 | 10:13 AM
bn
We put ours the swim platform and it works great. We have a Honda EU2000i. Runs A/C, fridge, batt. charger, etc.
I put a battery operated CO2 detector in the cabin.
bn is offline
Old 07-13-2005 | 08:13 PM
How big is you AC unit? Does the Honda generator start your AC unit w/o a problem? I have a 31ss w/ a 5000 btu Cruisair. Will the Honda 2000 start the 5000 btu unit without damage to the compressor?
ShootinTheBreeze is offline
Old 07-13-2005 | 08:17 PM
Ted G's Avatar
The 2000 will start a 5000 btu unit, but leave it on the platform during use.
www.cbpba.com
Ted G is offline
Old 07-13-2005 | 08:34 PM
bn
Yes the Honda 2000 will start the AC and mine is the 5000 btu Cruisair also.
bn is offline
Old 07-15-2005 | 10:18 PM
did your boat come with the cruisair or did you install it?
Old 07-16-2005 | 08:36 AM
bn
Came with it from the factory.
bn is offline
