Go Back  Offshoreonly.com > Owners Forum > Sonic
cabin leaks >
cabin leaks
cabin leaks
Old 10-06-2005 | 10:11 AM
45sonic's Avatar
Default Re: cabin leaks
Thanks Brian,
Anyone with any questions PLEASE feel free to call me. I will try my best to guide you toward a fix for your concerns.
45sonic is offline
Old 10-08-2005 | 07:27 PM
26sonicmotion's Avatar
Originally Posted by 43Thunder
Thanks Brian,
Hi,
I have a 2004 26 Prowler and twice this past summer I had water leaking in to the V berth coming from the Step Light. Not sure where the source of the water came from but it cleared up some how that I cannot explain twice. There is what looks to be a water line running port to starboard visible when you take the step light out. I believe it goes to the head and that possibly might be the culprit? I called Sonic and they never heard of a leak from that location before. I always store it nose up too.
Anyone have any suggestions?
Signed,
Pete the Navy guy stuck in Kuwait until next boating season.
:O(
26sonicmotion is offline
Old 10-12-2005 | 12:12 PM
45sonic's Avatar
Where is this light located? At the cabin entrance or at the base of the v-berth??
If the water line you are seeing is a fresh water line then check the fittings on each end to ensure they are not leaking.
45sonic is offline
Old 10-13-2005 | 06:08 PM
The light is located at the cabin entrance where you step into the cabin, just above the first step.
If it is the fresh water line, how do I get to the fittings on that line?
V/R
Pete the Navy Guy stuck in Kuwait until next boating season.
Old 10-17-2005 | 07:19 AM
45sonic's Avatar
I'll get back to you shortly
45sonic is offline
Old 10-17-2005 | 06:48 PM
GO4BROKE's Avatar
gofastgeorge remind anyone else of a past trouble maker?
[img][/img]
GO4BROKE is offline
Old 10-18-2005 | 01:07 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Seriously, what's the point? I read all of the posts. Is GoFastGeorge trying to piss off an OSO member, Sonic (whomever), or just the entire planet? What gives?
Sydwayz is offline
Old 10-18-2005 | 07:53 AM
45sonic's Avatar
Just the typical a$$hole that wants to put in his/her .02 that doesn't need to be put in. I think we have more than our share here in the Sonic forum.
I also want to thank the moderators for the great job they are doing in removing these intrusive posts.
45sonic is offline
Old 10-18-2005 | 08:22 AM
dido
sonic28 is offline
Old 10-18-2005 | 06:01 PM
45sonic's Avatar
V/R
Check the T-fitting under the sink on the port side and also the T-fitting in the head. Under pressure of course. If these are secure, you might be getting water draining from the bow, rubrail, bow light, or cleats. Also , if you have a flush toilet with holding tank and not a porta-potti check the fresh water line to it too.
Good luck
Bill
45sonic is offline
