Go Back  Offshoreonly.com > Owners Forum > Sonic
Stereo guys >
Stereo guys
Stereo guys
Old 03-12-2007 | 06:22 AM
hp500efi's Avatar
Member #9
Default Stereo guys
Looking to upgrade the stock stereo system in my 31.
Anyone running (4) speakers in the cockpit? if so, where did you locate the other (2) and is that a good location?
Anyone running a sub, if so what size, where is it located and is that a good location now that it is being used.
Anyone running more than the two stock batteries? I was thinking about installing an additional one.
Not looking to go hog wild ... just replace the speakers and add (2) more in the cockpit along with a sub and amps.
Member of the Liquid Jungle
hp500efi is offline
Old 03-12-2007 | 10:45 AM
Sloman's Avatar
I'm running 6 Pioneer i believe 6.5's and two 10 inch Clarion free air subs
two subs and 6.5's are mounted under the rear seat makes a nice Box
two 6.5's behind the Bolster ear level when sitting down in the back seat
two 6.5's infront of the bolster one right above the outlet on the passenger side and below the shifter on the drivers side have no problem hearring when running
alpine amp 600 watts and a sony amp 800 watts never had a battery issue
Hope this helps
Sloman is offline
Old 03-12-2007 | 07:18 PM
GO4BROKE's Avatar
4 Poly Planar 6x9's Under the rear bench, 2 Blaupunkt 10" subs in small ported enclosures in the side storage cabinets. 600 watt 4 channel amp, Sony head unit.
[img][/img]
GO4BROKE is offline
Old 03-12-2007 | 07:19 PM
GO4BROKE's Avatar
Needs more power.
[img][/img]
GO4BROKE is offline
Old 03-12-2007 | 07:51 PM
Hi Jeff, How's it going? I've got 2 pair of MB Quart 6x9's. The front ones are below the passenger's cup holder and the shifter. On my 26 the water tank is behind the port front speaker but there is enough room, just be careful when you cut the hole! I've got an Eclipse 4x75watt amp and it's not enough when running. Steve
509 SC is offline
Old 04-05-2007 | 09:21 PM
HI i have a 38 donzi and we installed 6 6.5 inc kicker speakers, 4 12 inch kicker subs and 4 tweeters, we have 3 2500 watts digital kicker amps and we added 2 additional bateries on a seperate battery system we have 4 of the speakers and 2 subs and 2 tweeters under the back bench and a sub and a tweeter and a speaker next to each bolster if it can fit in a donzi it can fit in sonics much larger cocpit good luck theres nothing like blasting music while running the boat
trickedoutdonzi is offline
Boomer35
03-18-2006 04:57 PM
OldSchool
02-07-2006 07:05 PM
Boomer35
02-03-2006 11:28 AM
NotTOOBAD
02-14-2003 12:03 AM
