Go Back  Offshoreonly.com > Owners Forum > Sonic
sonic pump out head ? >
Old 01-27-2009 | 12:54 PM
bigboat28's Avatar
ECB what year did they start putting tanks in all the 31SS?
bigboat28 is offline
Old 01-27-2009 | 02:54 PM
East Coast B's Avatar
I had talked to Bruce at Sonic and I believe the answer was 97-98 and newer models....
East Coast B is offline
Old 01-27-2009 | 03:45 PM
Plum_Crazy's Avatar
I have to look. I was just in that compartment to install new fuel fills. I don't recall seeing a tank. But, it may have carpet in the way. There were some water hoses that didn't go anywhere.
Plum_Crazy is offline
Old 01-27-2009 | 08:09 PM
Plum_Crazy's Avatar
There's no holding tank on my '03.
Old 01-28-2009 | 07:08 AM
My buddies 2003 26 prowler had a portapotti but the holding tank was in place and just ready to be hooked up....
What were the extra water lines you referred to for?
If you look behind the dash, are there any hoses in there?
Old 01-28-2009 | 07:20 PM
GO4BROKE's Avatar
Anyone know where the tank is in a 386? I suspect that it is under the floor. I would like to install a gauge for both the waste and the fresh tanks. Don't like to guess how full the waste tank is
[img][/img]
GO4BROKE is offline
Old 01-29-2009 | 09:34 PM
Plum_Crazy's Avatar
I wish I knew. They do not come into the area behind the dash. The only water line there is for the sink.
Old 01-30-2009 | 05:15 AM
That's a bummer they didn't install it, with the tank it's a no brainer for an install. Getting that retrofit tank in is doable but a headache.
Old 07-09-2012 | 09:30 PM
Anyone have any pictures of a install or steps on how you installed it?
QuickZX is offline
Old 07-10-2012 | 08:22 AM
I have '03 358, if you open the lower door in the bathroom and look aft, there is an access panel behind the A/C Unit if you have it. Mine was a board with black carpet, I had to peel the carpet off to access the screws that held it in place. Remove that panel and its directly behind that, its actually located directly below the driver's step under the steering wheel.
My down spout tube fell off and wasn't allowing me to pump anything out this season, it was certainly a $hitty job. All I can say is that I do not see how you could possibly replace it if something ever happened to the tank itself. If you have A/C installed I hope you're a small guy because they don't give you much room to work.
vettex1 is offline
