Go Back  Offshoreonly.com > Owners Forum > Sonic
Slimline pull-up cleats >
Old 03-03-2008 | 10:14 AM
Jim Diesel's Avatar
"Unregistered Gun"
Default Slimline pull-up cleats
Has anyone switched from the standard fixed cleat to the slimline pull-up cleats, If so did you go with the 6" or 8" cleat?
Jim Diesel is offline
Old 03-03-2008 | 12:12 PM
Quiet Storm's Avatar
I changed mine out to the 6" size. I had to make adapter plates to cover the old holes. They turned out great. It was nice to get rid of the old style that held water all the time.
Quiet Storm is offline
Old 03-04-2008 | 03:46 PM
Jim they have had some problems with sonic's leaking because of the roughed up walk around not sealing with a hole having to be cut to accommodate the cleat. People have used huge amounts of silicone to help keep the water out. I'm thinking about two in the back where it is flat.
45SS is offline
Old 03-04-2008 | 04:11 PM
Jim Diesel's Avatar
"Unregistered Gun"
Thats what I kind of figured, Thanks Jimmy
Old 03-04-2008 | 06:31 PM
anyone have pics of this done..... I have the recessed type that hold water and have thought about this myself.....
Here's Johnny is offline
Old 03-09-2008 | 12:28 PM
26sonicmotion's Avatar
Leak City! From day one on my 04' pop up's, they leak from the down tube's on the underside of the cleat..... What a pain having to dry out under my v berth pad. One of the worst lack of attention to details Sonic has made. There is a cheesey little sticker covering the hole in the down tube and when the sticker fails to stick any longer, water just drips right through it. Come on Sonic!!! A sticker?!?!? Sould be drain tubes on them or something! I have had to try and wrap watertight tape around it....what a pain trying to seal this up reaching your arms through the speaker holes to seal something that shouldn't need to be messed with on a brand new boat. Also under the bow nav light, water gets through there too and two spots where the factory screwed the boat together at gunwhale at the bow, was not sealed at the screw holes, and water just drips through there too. Yup had to seal that too..... I guess I gotta go in behind the v berth mirror again this spring to make sure she is water tight.
Anyone else with similar problems?
Pete
26sonicmotion is offline
Old 03-09-2008 | 06:46 PM
Pete exactly why Richard Hewit no longer has anything to do with Sonic,(alot of his bright ideas failed) and Jay never used them, he new better.
45SS is offline
Old 03-09-2008 | 11:15 PM
Z06
Johnny, keep a turkey baster on board to suck out the water, works well and you don't ever need to worry about these hidden cleats ever leaking water.
Z06 is offline
Old 03-10-2008 | 07:32 AM
Sydwayz's Avatar
Forum Regulator
Pete
Oh yeah, been there. My '99 Prowler's navigation light base was cracked and filled that little void in behind the mirror/speakers with water. I had to seal up everything with clear RTV, and I eventually drilled a little hole at the base of the mirror so any moisture would leak out; and I would be able to notice it. I too had a very wet V-berth pad. I removed the foam and encased it in plastic so this would never happen again.
Ask Bill/45Sonic how many times he has dealt with this.
Sydwayz is offline
Old 03-13-2008 | 06:09 PM
good idea.......thanks.....
Anarchy Powerboats
05-11-2006 12:10 PM
Quiet Storm
3
02-10-2004 06:17 PM
Sydwayz
05-23-2003 01:08 PM
JohnJan
01-06-2003 01:11 AM
GO4BROKE
Sonic
9
08-15-2002 06:20 PM
