Go Back  Offshoreonly.com > Owners Forum > Sonic
Anyone had this problem >
Old 04-29-2008 | 01:20 PM
Jim Diesel's Avatar
"Unregistered Gun"
Default Anyone had this problem
Check my thread out in the tech forum, but my tach and gas gauges are eratic when im running?
http://www.offshoreonly.com/forums/s...29#post2542129
Jim Diesel is offline
Old 04-29-2008 | 01:50 PM
I would say batteries and Just for the hell of it ck the back of the gauges to make sure all is tight....Thats were I would start....
creeper is offline
Old 04-29-2008 | 04:13 PM
45sonic's Avatar
Those are new tachs in the boat. I have the old ones. Replaced due to "bouncing" issue. My Sonic's starboard tach does/did? the same thing. Hopefully with new gauges it went away.
Check all grounds starting with battery, especially under dash. Then as most agree replace plug wires.
45sonic is offline
Old 04-29-2008 | 07:48 PM
Pwrbt33's Avatar
I thought ck meant kick!! Its time to go home!!
Pwrbt33 is offline
Old 04-29-2008 | 07:52 PM
GO4BROKE's Avatar
I vote ground. Bad plug wires shouldn't effect the fuel gages.
Then kick it.
[img][/img]
GO4BROKE is offline
Old 04-30-2008 | 08:48 AM
John you monkey..........:..
creeper is offline
Old 04-30-2008 | 09:39 AM
carrboy's Avatar
Ground
carrboy is offline
Old 06-16-2008 | 07:45 PM
Jim Diesel's Avatar
"Unregistered Gun"
Fixed my bouncing tach issue had bad plug wires. Two wires ohm'ed out bad but never had a miss in either engine.
Old 06-16-2008 | 08:42 PM
BY U BOY's Avatar
Check harness plug.I was having the same problem with an oil press. gauge.Replaced wires,sender(twice)and the gauge.None of that worked. Pulled the harnes aprt cleaned with carb cleaner and a Q tip an problem solved.
BY U BOY is offline
Old 06-17-2008 | 06:37 PM
I have this problem with my starboard tack and volt meter.
Everything runs OK. It only does it sometimes.
myturn is offline
