White Rubber Rub Rail
I don't know which engines you have. But, if you have the 496HO's, there was a flash update in '03 which resolved a large part of the soot issue. I went from having a black transom every time out to just a light film after the update.
Whenever I have a mark on my rub rail that can't be washed off, I use 400 grit sandpaper. Works like a charm.
You might want to start a thread about it I know some guys soak it in a hot bucket of water to loosen it up!
I have the same issue with mine getting dirty with everything that touches it. All cleaners above work well and I have also used gojo w/ pumice. the grit in the gojo works well.
I've always wondered if cleaning it with these products takes away whatever protectant (if any) that was on the rubber insert. I wonder if once we get it clean, we could put something on it to seal the pores of the rubber so dirt doesnt penetrate so easily ??? some type of clear sealant ? or will that just yellow over time, and then you cant get it off ???
We bought ours from Sonic and put it in two weeks ago. Took Bill and I about 1.5 hours. Left it in the sun on black asphalt to warm it up. Used Simple Green, a flat blade screw driver and a rubber mallet. Not hard at all.
Patti
Patti
