Go Back  Offshoreonly.com > Owners Forum > Sonic
Trim & Tab cables >
Trim & Tab cables
Trim & Tab cables
Old 05-18-2010 | 05:06 AM
I took apart the port side heat exchanger last night. Nothing in it. Completely open. Using the garden hose I flushed all the hoses thru & still nothing. I would think it has something to do with the pump. I am starting to wonder if I didn't have the belts on tight enough to spin the new stiff impellers. I basicaly tightened the belts to match how I found them. Possibly the pump pully was slipping. The belts looked like they need replacing. A little on the dried out side from sitting. New belts on the way as well & R&R kits on the way.
Quinny is offline
Old 05-18-2010 | 01:31 PM
My 496 does not pull water unless I give the throttle a blip on start up. Just enough to stop it cavitating and get water circulating then its fine. These water pumps are apparently prone to this from picking up debris and scoring the back plate.
It is my plan to overhaul the pump in time but this has worked fine for me in the meantime, it circulates strong once it gets going.
simon1401 is offline
Old 05-18-2010 | 01:43 PM
Ted G's Avatar
You also may need to look for a collapsed hose at the transom assembly, at least run the hose on the drive and pull the feed hose that comes from the transom and see how much flow you get. I just did mine and one of the hoses was squeezed down about 1/2 by corrosion between it and the housing.
www.cbpba.com
Ted G is offline
Old 05-18-2010 | 09:18 PM
upstate31sonic's Avatar
Originally Posted by Quinny
Thanks for the replies. Looks like I have bigger problems to deal with first. Dropped the boat in the water, fired her up, no water coming out the exhaust. I just replaced the impellers last week. Whats odd is that both engines did the same thing. Didn't take long to start heating up. I took apart the starboard side sea pump just to be sure the impellar was in right So know begins the fun eliminating possible plug ups. Going to start with the heat exchangers.
This may be dumb to ask!!!! But I will ask anyhow...On my pumps it is possible to have the hoses backwards...I do not think that you said what power you had..I have a friend that when through his carb 500s and forgot where the inlet and out let went..He asked a mechanic that worked at one of the larger marinas in A-Bay how to hook them up and he told him wrong...Just a thought
upstate31sonic is offline
Old 05-19-2010 | 07:53 AM
I currently have the front of the pumps of leaving the back plates attached to the hoses. If I take & put ear muffs on the drive & flow water thru it should the water be coming out of the top or bottom hose conected to the pump? I think this will tell me if my inlet hose is ok. I have 496 ho's.
Quinny is offline
Old 05-19-2010 | 02:39 PM
Hope some one steps in here..I only am up on the pumps on my efi500..On the back it gives a arrow for the direction that it turns and lets you know where the inlet and outlet would be
Old 05-19-2010 | 02:55 PM
Ted G's Avatar
Looking at the diagrams on mercruiserparts.com it looks like the inlet is the lower hose, so water should flow forcibly from there.
www.cbpba.com
Ted G is offline
Old 05-20-2010 | 04:06 AM
That's what I thought. Thanks for the reply. Tore into it a little more last night. Still no blockage found. Just waiting for the pump rebuild kits to arrive. I'm realy starting to think that is the issue. There are some pretty deep grooves in the brass.
Quinny is offline
Old 05-28-2010 | 09:23 AM
Took the boat for a spin last night. Everything worked perfect after new belts & the R&R rebuild kits. Thanks for all the help/sugestions. Just in time for the long weekend.
Quinny is offline
Old 05-28-2010 | 09:45 AM
Plum_Crazy's Avatar
Gotta love those R&R kits. I can't believe they don't make more of an attempt to market them.
Plum_Crazy is offline
