Go Back  Offshoreonly.com > Owners Forum > Sonic
1st Weekend With The 31 - Impressions >
Old 08-09-2010 | 09:28 PM
Best I saw was 72.1 on GPS 1/4 tank of fuel 4 people on board turning 4900 RPM. Funny, Sonic shows a 12V outlet in both the cabin and cockpit as standard features but my boat has neither. They also show a swim ladder as standard and mine doesn't have one either. At 3500 RPM I was seeing 50 - 52 MPH (GPS). I do know I need to replace the batteries but even with fresh batteries it may be best to tell the wife to only run the fridge when connected to shore power ! I also have the infamous "dead" battery on the Livorsi GPS speedo not sure if I am going to undertake the battery change myself or send the antenna back to Livorsi. Only other issue I noticed was that the port engine temperature would occasionally run 5 - 10 degrees higher than the starboard engine, but at other times they were the same. Not sure if it may just be the gauge or sending unit but in either case neither engine went above 170 degrees.
MDsteve410 is offline
Old 08-10-2010 | 07:40 PM
exmark31's Avatar
My water temp does the same thing.
exmark31 is offline
Old 08-10-2010 | 09:07 PM
You can also add the ladder yourself, I did on my Prowler and had AT use the same one on my 33. It's made by Windline, I think Baja also used the same model on their boats. Steve
509 SC is offline
