Go Back  Offshoreonly.com > Owners Forum > Sonic
Closed the Deal on the '99 Prowler >
Old 01-23-2011 | 07:42 AM
Default Closed the Deal on the '99 Prowler
Well, looks like I have finally joined the Sonic family. Closed the deal on the '99 Prowler Friday. I live in MD and have to go to Stuart, FL to get it. Deal is contingent on my inspection and a demo ride. I'm pretty boat savy but are there any Sonic specific things I should look for?
My only concern is the trailer tires. I may replace before I head North. Owner garage kept the boat but will have to check the DOT tire manufacture date.
The boat is on a Rocket trailer and from what I have read on this site they are not considered good trailers. Since this boat has mostly fresh water hours I'm assuming the trailer is in decent shape. From the pictures it looks OK.
Would appreciate any feedback.
Ed
U4ICK is offline
Old 01-23-2011 | 08:02 AM
get a survey
mikebrls is offline
Old 01-23-2011 | 08:05 AM
congrats on the purchase and I agree it's worth it to spend a few bucks to get a survey done
andyt25 is offline
Old 01-23-2011 | 08:25 AM
GO4BROKE's Avatar
Get a survey done, pay to have the trailer bearings and brakes serviced if the survey is good. Bring 4 spares on rims and everything to change them with you. You can get tires and wheels reasonable here:
http://www.etrailer.com/maindept.asp...FdID5QodUhuIwQ
A spare set of bearings would be a good idea too.
[img][/img]
GO4BROKE is offline
Old 01-23-2011 | 08:32 AM
GO4BROKE's Avatar
Oh yeah, Congratulations! Hope it goes well. You might consider having them send you video of the whole boat too. I flew to Chicago to look at a 42SS that was trashed (dealer said it was very clean). Looked great in pics, even in the pics I took of it. From 50' away my first thought was "I can't bring that POS home". I also discovered the engines weren't what the said they were. Cost me $700 in airfare and car rental to find out. Dealer was enough of a Dick to get mad, red in the face, that I wouldn't sign the contract to buy it. I did get my deposit back though.
[img][/img]
GO4BROKE is offline
Old 01-23-2011 | 10:44 AM
45sonic's Avatar
Survey for sure.
I've trailered a LOT of boats on Rocket trailers, most have been good experiences. The smaller trailers have a tendency to wear tires due to incorrect boat placement or uneven toe in of the axles. Also depending on how the trailer is set up for boat support depends on how the trailer performs too. They designed them two different ways --- adjustable bunks and non adjustable bunks. The non adjustable ones tend to be better, but for a smaller boat it is likely its the adjustable style.
PM me if you need any help
Hey, Go4broke is right, DO NOT believe anything til you actually see it. We both looked at the 42 he mentioned. POS !!!
Good luck
45sonic is offline
Old 01-24-2011 | 06:53 AM
Originally Posted by 45sonic
Survey for sure.
Good luck
45Sonic............thanks for the trailer advice and the help offer.
Before I leave FL I'm going to check the tire manufacture date and if over 6 years old I'll probably get 4 new tires before I start back. I had good tires on my Scarab trailer until the belts started splitting. The tires were 7 years old and were in the sun a lot. Also going to jack the trailer and check for bearing play and pull the bearing caps and make sure there is grease and no grease and water mixture.
I hear you about your POS experience. The contract I signed says the deal is contingent on my inspection and the demo ride. The deal is off if either goes nipples skyward.
Again, thnaks to all for the info.
ED
U4ICK is offline
Old 01-25-2011 | 06:24 PM
Good Luck with the deal........Just a fyi....I had a 98 Prowler(pur.new) with a Rocket it was junk, bearings were junk.....and even had a leaf spring snap in half on the front axle pushing it into the second.Thank god I was pulling if with a F350 Dually super crew.(the only thing the trailer had going for it was the Diamond Plate fenders that were strapped well)Didnt touch the boat haul).Check the trailer very well.....oh and rockets customer service sucks....at least in back then it did.....Sorry if I am ranting but hearing the name Rocket Trailers brings back nightmares.........
creeper is offline
Old 01-26-2011 | 01:10 PM
Congrats on the Prowler purchase ! I can echo the sentiments with regards to Rocket trailers. They are JUNK ! My 31 is on a triple axle Rocket Trailer that has left me stranded a couple of times ! Wheel bearings have failed wiping out the axle spindles (you have to buy the entire axle), brake calipers installed upside down, incorrect tire weight ratings, etc. I took mine to a local trailer repair shop and had ALL the wheel bearings replaced, brakes reworked, etc. With what I paid for the trailer plus the repair / service costs I could have gotten a Myco !
MDsteve410 is offline
Old 01-28-2011 | 09:39 PM
I was actually impressed with the Rocket I have. For 11 years old it did well. I had to get 4 new tires. That was a given before I left. The DOT date on them was 0501. Not worth the headache with 10 year old tires. While they did the tires I pulled and repacked all of the wheel bearings. Checked the surge brake and that was OK. What surprised me is no leaf springs. I have torsion suspension on my Rocket. Had to extend the wire harness 1' to reach my truck connector and clean 4 grounds to get the lights to work. The tailer did not present one problem from Stuart, FL to southern MD.
Ed
U4ICK is offline
