496HO riser is blistered - Overheated?
All,
Looking for some info. I just had my 26 Sonic winterized and the shop advised I needed a new impeller and water pump as the water was not pushing through on the Port side when they ran it to winterize it. I went to go look at it today and noticed the Port side paint is blistered on the header real bad. If they ran it just for a minute and no water went thorugh, would it blister that much from just that little bit of running in the shop? The Mechanic said they did not have it running very long at all and shut it down. I am having a hard time with what they are saying. They also had to replace the rubber exaust hose to the transom as that melted too. Any info would be greatly appreciated. |
They get pretty hot, pretty fast, but you get smoke and burning odor before damage is done. It only takes a few minutes, 3-5 to start to overheat. I'd say they weren't paying close attention.
Originally Posted by GO4BROKE
(Post 3560420)
Thanks for the info. Much appreciated. I am making them re paint the header. They tried making it seem like it was blistered when I dropped it off and it over heated when I last had her out. That definitely did not happen. |
[QUOTE=26sonicmotion;3560581]Thanks for the info. Much appreciated. I am making them re paint the header.
I beleive, the manifolds are powder coated not painted...... powder coat holds up much better. |
[QUOTE=45Tripps;3561453]
Originally Posted by 26sonicmotion
(Post 3560581)
I beleive, the manifolds are powder coated not painted...... powder coat holds up much better. Is it summer yet? Can't freaking take the snowmobile out since there is no snow. This stinks! lol! Pete |
I was thinking of the Gill manifolds. The 502 MPI manifolds were painted Merc Black. If you have a 496, cant speak about those, have no experience with them.
Originally Posted by 45Tripps
(Post 3590393)
It sounds like you have pieces of the impeller in the sea water side of the exhaust which is causing the overheat. It needs to be disassembled and back flushed. Usually, it's best to try and account for all major pieces of the impeller by trying to match them up once all are popped out via backfluahing.
Originally Posted by Sydwayz
(Post 3696897)
Pete |
Bad hose clamps
2 Attachment(s)
Attached are a couple of shots I took of my
riser problem last fall. The problem was hose clamps that Mercury uses. One of them corroded and popped of while I was running. No alarm just a fire and smoke coming from the engine compartment. All cooling water to the riser went into the bilge so the riser quickly over heated! I shut the engine down and the fire stopped. What a mess. It took me four hours to idle home on one engine. One thing to Mercury's credit is that the closed cooling system protected the engine from any damage. |
| All times are GMT -5. The time now is 06:36 PM. |
