35 ss prop help
I finished removing the hook, it wasn't too bad to do.
I also found that the foam in the hull is water logged.
I removed all the foam from the v berth through 3 deck plates and cut out the cabin floor to remove foam. Total of 300 lbs of wet foam removed .
I'm going to run the boat on sat , I hope these things get the bow to carry
No it doesn't burry the bow and longer , but it's strange that the boat feels like its lighter in the bow and reacts to trim better but 5 mph slower on gps. I tried the same props spinning the same way that I got 84 mph now I only get 78.8. Only difference is now I'm 100 rpm lower
I tried spinning props out again but there was no change
