Speed and set up?
#31
Registered User
2003 31ss 575sci's, superchillers, modified ECM's, ported heads, full roller cams, and other "assorted" goodies
Running XZ's at the time, now running XR's... a tad bit slower as they take at little more HP to turn... still mid 90's.
Boat is also fully loaded ammenity wise too.. a/c, fridge, microwave, tv, dvd, ect...
The GPS does not lie...
Water was 2' chop, fuel was almost gone, 1 passenger, wind behind us, 6000rpm (rev limiter set to 6800), 32P bravo 1's labbed, starved myself for a week to loose 10 more lbs lol...
#32
Assuming 1.5 ratio and 5000 rpm's (should be 5400), that is 17% slip. My boats are usually 12%. Spinning a 30 to 5400 @ 12% slip would put you at 90. I would expect you to swing a 34 or so with 850hp. I think you need to look at your set up. I had a friend running 10 mph faster than you with tweaked 525SC's. I don't remember what prop.
[img][/img]
[img][/img]
