Go Back  Offshoreonly.com > Owners Forum > Sonic
Bravo1 /hose is disconnected? >
Old 08-03-2013 | 10:54 PM
Default Bravo1 /hose is disconnected?
Hi to all, figure I would ask the pro's,,,have bravo1 drive & noticed a1/4" rubber hose not connected to any thing on drive,looks like it comes out of /thru transom housing ,this hose is not leaking any fluid , but can't find where it would connect? Maybe I'm looking at just a vent hose? Motor&drive seem to work fine , any help would be appreciated,thanks to all
26 sonic is offline
Old 08-04-2013 | 01:44 AM
That's the speedometer pitot hose.
Unlimited jd is offline
Old 08-04-2013 | 03:24 AM
Where would it connect on the drive?,I have speedo pickup on transom already, should I plug this hose?
26 sonic is offline
Old 08-04-2013 | 03:27 AM
There's a plastic nipple on the front of the drive in the middle of where the u shaped zinc bolts on. If you have another speedo setup just leave it alone. If no water is leaking into the boat it's fine
Old 08-04-2013 | 06:47 AM
Thanks lil red
26 sonic is offline
