Looking at 02 Sonic 31ss...
going to look at 02 31 ss. Any particular things I should keep an eye out for. Boat looks very clean but just checking Thanks!
As far as I know there are not any inherent problems with these boats. I would recommend looking it over carefully however and if you want to do the deal to get a survey done. Even though they are great boats, a bad owner could have made it a not so great boat.
Looked at it today. Has two gas tanks how many gallons are each. Had a crack at bottom of cabin entrance on the inside other than that clean boat
It should be 2 90gallon tanks. As far as the stress crack by the cabin door that shouldn't be a big deal. They are great riding boats with lots of creature comforts/features that make boating more fun and easier.
I beleive the fuel capacity is (2) 70 gallon tanks. In regards to the surface cracks in the gel... Not to worry... If it was structural...walk.
Originally Posted by teamsynergy
(Post 4105775)
Mine has a crack in the same spot, I have 2 70 gallon tanks- I had to replace them last summer
My 26 had a crack im the same spot, no biggy!
How does this boat ride at cruise does it pull the bow up some or run level coming out of a 311 sr1
The ride will depend on the props. I had a set of props labbed and it did not ride as well as it did with the stock Mercury bravo's.( labbed for speed) I did own a 31, they are great riding boats. As far as size in the cabin it would be night and day compared to a 31 Formula the Sonic is big down stairs. Mine had 500EFI's It would run over 80 on any day 83 was the best.
| All times are GMT -5. The time now is 04:20 AM. |
