Go Back  Offshoreonly.com > Owners Forum > Sonic
31ss that runs 80+???? >
Old 11-02-2002 | 09:35 AM
  #41
cougarman's Avatar
Default Hmmm.........
Sounds like we are getting a little
closer to reality, X-dimensions, junk
speedo's.
Cougarman
cougarman is offline
Old 11-02-2002 | 11:38 AM
  #42
dyno's Avatar
Charter Member #655
I've never put any stock in my speedo...its barried at 80+ when running 74 on GPS but the tach I've never suspected to be wrong........if it was off significantly I think I would be able to hear it......
If your boat has a sail do you ride a horse to the ramp?
dyno is offline
Old 11-02-2002 | 11:41 AM
  #43
http://www.boatramp.com/prop_applet/...erAppletG.html
play with the math and let us know what you come up with
chances are the tachs are correct or w/in 100rpms.
audacity is offline
Old 11-02-2002 | 11:52 AM
  #44
dyno's Avatar
Charter Member #655
Looks like for the #'s to work out I'm running closer to a 25 pitch prop.....thats if the #'s are right.....what is an exceptable % of slip?13-15?????
dyno is offline
Old 11-02-2002 | 12:03 PM
  #45
well lets just say a FULL blown F2 race boat will be in the 11-13's....what # does it say on the side of your props!??
audacity is offline
Old 11-02-2002 | 12:07 PM
  #46
dyno's Avatar
Charter Member #655
dyno is offline
Old 11-02-2002 | 12:12 PM
  #47
well....let's say you changed the original gearing to 1.36 and turned your 23's to 5100....at 74 mph ....that under 10% loss...better than any v hull i know. are these the same props you used prior to your engine mods/rebuilds?
audacity is offline
Old 11-02-2002 | 12:14 PM
  #48
do both of your tachs read the same at WOT??
audacity is offline
Old 11-02-2002 | 12:22 PM
  #49
dyno's Avatar
Charter Member #655
both Tachs read the same and no I havent changed props since the engine up grade...I did have one toughed up after I hit some sh@#......
dyno is offline
  #50
what was your max RPM at WOT prior to??
audacity is offline
