Prop selection for 358 with 500efi's
Re: Prop selection for 358 with 500efi's
Originally Posted by splashandburn
I have a 2002 358 with the HP500 EfI's that I bouight over the winter. The boat had stock 28 Bravos that gave me about 4800 rpm and close to 78 mph (gps). I had the boat into Sonic and they swapped out the props for me with labbed 28's. Now I can hit 5200 rpm but only run around 74 mph. I'm thinking of going back to the stock 28's because of the speed issue but isn't it better to run in the upper range of the max rpm??
I have 525's with labbed 28's and get about the same numbers as you do with the labbed props .I am going to try a set 30's that are labbed
I will let you know I have a 2003 358
Thunder32,
Try bringing your tabs down alittle(even with the running surface).this may help. It did with mine. My hull has the notch in the transom.
Originally Posted by roadrunner
I always felt that way until someone goes by me at a couple miles per hour.
Got a chance to get the boat wet . I ran the 30 lab finished
ran the same numbers as the 28's but now boat was full of gear
wife and two daughters full of water . So I have to say I picked up
a little ran 5200 rpm around 77.6 w/short blast
Water was flat .What I really liked was 3000 was around 43 mph
Originally Posted by Thunder32
thanks Splash-
please post results when you can.
Adam
Adam
I get alot of the porpoising too. I've indexed my drives and tabs to neutral - approx 4 on the drives and 5 on tabs. I have to run with more than 5 tabs or I start to get alot of front end bounce - no notch either. Where are you other guys running your drives and trims with your 358's?
When we are running 40-50mph
I always set tabs at around 5 give or take a little on each
The drives are set around 2-3 for the same speed . This seems to
stop the bounce . when I want more speed I just flatten or 0 out the tabs
and run the drives as far out as the rpms will let me (flat water ).
I found the sweet spot and marked it on my tab indicator with a dot from a sharpy seems to make it a lot easyer to find while moving. Hope this helps
RR
RR
I have an 05 358 with Bravo 1's 30 pitch. I ran 79.9 on flat water but i have to run a lot of tab initially to keep the bow from bouncing. Has anyone found props with enough stern lift to keep the bow down. pic's attached
