Go Back  Offshoreonly.com > Owners Forum > Sonic
Tow Vehicle for '04 31SS >
Old 09-19-2004 | 11:28 PM
Prowler's Avatar
Charter Member #1472
Default Re: Tow Vehicle for '04 31SS
Here's the retired GMC 2500.....
Prowler is offline
Old 10-29-2004 | 11:14 PM
Scott Morehead
Ford F-250 diesel 380 miles roundtrip a weekend all summer no problem with my 2002 31ss. Hardly know it's there
Scott
Old 10-30-2004 | 06:36 AM
"no such thing as to much truck"
truer words have never been spoken!
04.5 Duramax/Allison here pulling 353 Formula and Eagle. 12K + lbs.
I will never tow anything more than a 20' bowrider with a gasser again.
Of course that 20' er was six boats and 15 years ago.
Rippem is offline
Old 03-23-2005 | 07:51 PM
I pull my 30ss with a 6.0 litre 2000 chevy In and out all day long.
alexsilverado is offline
Old 03-24-2005 | 05:46 AM
East Coast B's Avatar
If your ever planning on going bigger in the future, flip the bill for a diesel now. You'll get by just fine with a 2500 series truck with the bigger gas motor to tow your 31 now, but anything bigger and you'll wish you went with the diesel. My thoughts are, spend your money once for a vehicle that will do the job now and in the future. I'm in Pennsylvania and when I hit the hills, I'm thankful there's a diesel under the hood, abosolutely love it and the gas mileage is great. As for which diesel to get, I think they all have good engines these days, it's personal preference. I've always been a Chevy person, but opted for the Ford since it gave me more leg room with the adjustable pedal option. Chevy by far has the best extra cab room. Good Luck!
East Coast B is offline
Old 03-24-2005 | 07:20 AM
dyno's Avatar
Charter Member #655
Originally Posted by Sydwayz
Minimum would be 6.0L Gasoline 2500HD GM.
There is no such thing as as "too much truck."
My pick would be a 2500HD GMC with Duramax Diesel and Allison 5A Transmission.
Yep! what he said.
If your boat has a sail do you ride a horse to the ramp?
dyno is offline
Old 03-24-2005 | 06:25 PM
shewbart's Avatar
I pull my 04 31ss with a z71 Tahoe it works just fine unless you want to go where there is an area like austin texas with a lot of hills then fugetaboutit. Braking is going to be a little hairy if wet and make sure they are disc. I would recommend a 3/4 ton diesel as the others have said.
Cass
shewbart is offline
Old 03-25-2005 | 11:50 AM
ST31's Avatar
I used to have a 2wd 1995 Ford dually that pulled well except getting up the wet ramp. Now I have a 2004 F250 Crew Cab 6.0 that pulls the boat better than anything else I have been around.
Really depends on where you boat. Like Shewbart said, places with hills like Austin can really cause trouble for transmissions and brakes if you are towing with the wrong vehicle.
ST31 is offline
Old 03-29-2005 | 10:00 PM
I have weighed my 2004 31 SS and it came in on the trailer with full tank of full, 5 gallons of water plus gear on board and the 3 axle rocket aluminum trailer with disc brakes - just at 10,000 lbs. The trailer alone was 1,500 hundred.
I've towed it for 20 miles on non-highways with a Tahoe Sport version with heavy duty suspensionn - don't recommend for any distance on the freeways. They I've towed with my GMC Yukon Denali (6 litre) - great for short distance, again not rated for 10,000 lbs.
Should be a minimum 2500 and preferably a 2500 diesel.
islandracer is offline
Old 03-30-2005 | 01:04 AM
VIPER7's Avatar
islandracer, I have a 2001 2500 GMC with Durmax diesel and 5 speed Allison transmission. I had 95 31SS and I currently have a 2005 358 and the truck has done a great job of pulling either one. Didn't you buy the 31 that was suppose to go to the Miami boat show last year?
VIPER7 is offline
