Go Back  Offshoreonly.com > Owners Forum > Sonic
Sonic bolster ? Too Old??? >
Old 09-29-2004 | 07:02 AM
dyno's Avatar
Charter Member #655
Default Sonic bolster ? Too Old???
Hey Fred or anyone else that may have removed some bolsters from a sonic...are they through bolted or screwed into a block? I want to replace my carpet and put snap-in in my 31 its glued down now....
Don
If your boat has a sail do you ride a horse to the ramp?
dyno is offline
Old 09-29-2004 | 07:58 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Default Re: Sonic bolster ? Too Old???
My 1999 Sonic was screwed down.
Sydwayz is offline
Old 09-29-2004 | 12:14 PM
45sonic's Avatar
Screwed in to the floor and bolted to the sides
45sonic is offline
Old 09-30-2004 | 01:57 AM
Mark in So. MD's Avatar
mine was the same
Mark in So. MD is offline
Old 09-30-2004 | 06:33 AM
dyno's Avatar
Charter Member #655
Thanks guys!!
dyno is offline
Old 10-21-2004 | 09:58 PM
blown formula's Avatar
I put a 4" access port (screw in) and installed stainless T-Nuts from under the floor. A lot more secure since the floor is foam cored with a thin layer of glass on both sides. I used stainless button head bolts thru the mountings. Easy to remove and doesn't mess up the hold threads.
blown formula is offline
Chris Sunkin
Cigarette
0
03-08-2008 06:29 PM
SKRAMER
02-26-2008 08:23 AM
Tony Montana
Active Thunder
2
06-05-2007 10:38 PM
gofast000
Sonic
34
11-25-2006 07:01 PM
302Sport
09-12-2006 08:53 PM
