Weight of your sonics?
The weight of gas varies depending on temp. The weight of 1 gal of gas at 72 degrees F is around 6.25 lbs. per gallon. Cooler temp = more dense gas = more wt. Higher temp. = less dense = less wt. So I guess the solution is to live in South where the weather is hotter thus less wt. for full tanks!!
Originally Posted by rookie2
anyone know what a 1989 30ss would be thank you
If your boat has a sail do you ride a horse to the ramp?
I've just learned that the weight increases proportionatly to the increase in road grade when towing up hill!!!!
I also learned that the weight of fuel decreases proportionatly to the increase in fuel prices.
Findings... To counteract these affects, I need to buy a dock and a sailboat!
NOT!
NOT!
