Ky Lake Poker Run
#32
Registered User
Ok peeps, If there is anyone else let me know by 9 am in the morning, Other wise the slips are full. Its gonna be a great time. So far there are about 60 that are coming for sure, and with the weather working with us this weekend im sure you can count on about 20 more. This should be the biggest poker run kentucky lake has ever seen. Thanks to mitch mowery(mama tryed) for all of his hard work in putting this event togather. And the family support group of the kentucky national Guard for their hard work to.Thanks to the MCPA for members for contributing to such a good cause.See you all on the water. If you need directions to kenlake here they are....From nashville get on I-24 headed towrds Ky when you get to exit 65(cadiz get off the interstate and make a left hand turn. that will be the last place for fuel and munchies.continue on highway 68 crossing to bridges. The first will be barkley lake and the second will be kentucky lake. After the second bridge you will turn left at the second Kenlake entrance and proceed to the boat ramp. Once you put in you will make an immediate left into kenlake harbor, and the dock will be on your left... If you have any questions you can reach me @ 1-270-210-0012 or Kathy @ 1-270-703-2368. See you on the water. Kathy and i should be @ kenlake by 1:00pm on friday after noon.....
#33
Registered User
Evan,
Did you remember to add me to the list? Ken
I plan on leaving work around 2PM Friday. Do you know of anyone else leaving Friday? Would like to ride with someone other than myself. Thanks. Ken Viken
#34
Ken,
That is about the same time I will be leaving Hendersonville, close enough so we will go together. I will have Charlie Barbera riding with me as soon as he gets off work and he is thinking about that time. I will need to stop at Sams to gas the truck and boat. FYI, I usually run 30 minutes behind.
We are staying in the boat at Kenlake Marina. That is about 23 miles by water south of Kentucky Dam Marina.
Liquidsation
Rob Oxford
826-0461
Liquidsation
Rob Oxford
826-0461
