Texoma BS Thread
#602
Have You Guys Ever Wrenched On A Boat To Kno The Effects Of Moving The Center Of Grav? Can Tou Tell Thats Where They Originally Should Be, Why Would They Build It Like That, And Now You Need Them Moved Back? not saying you dont know but it ran well before, there are things you can do to props to change the way it handles, i just cant see all that work for nothing.
#604
Jason, tell us whats going on. If nothing else, we would like to arm chair engineer this thing with you.
#605
) This pushes the weight way too far forward. Boatstarts to climb out of the water but cant hold the bow which falls then it happens all over again probably once a second with lots of magnatude at 100. Larry Goldman has rigged about 50% of the 35 Motions. He has won multiple world championships in the 35 motion. His boats are fast and run flat. When I asked about this boat he instantly said he knew the boat. He said they mounted the motors way too damn far forward. Move them back, 18-22 inch shaft, fast flat boat, done deal. Ive had no less than Brad Schoenwald in the boat who said set-up was screwed..."let Larry set it up". This aint my 1st rodeo guys. I wasn't aware of the set-up till I ran the boat but instantly knew it wasn't right. They either were planning on putting 2800-3000 HP in this boat or had a "bright idea" or didn't know what they were doing when they placed these motors.
#606
Whats going on is there are multiple 35 motions which have been built with good power and sixes. They all run an 18-22inch shaft. These boats run flat and are very fast. My boat was rigged by someone in Florida who had never rigged one of these boats. My shaft is over 34 inches long. (Don't pull that out of context
Got ya. What is that going to do to your drive shaft angle?
#607
OkieTunnel, I can think of several ways to change the CG besides moving the motors. That is at least twenty- thirty grand if you have it done and done right....What about starting by moving the batteries to the transom and sand bagging the transom with enough wt. to get it flat. The next concern will be getting on plane w/enough X dimension to get the props out where they belong....Do you have a ballast tank?
#609
