NADA and Loans for Spectre
In anticipation of finding a used 32 Spectre with Optis, I wanted to check NADA value. I cant find the 32 Spectre on NADA. I also don't see the 30's. My credit union specifically uses NADA. Any idea why these boats aren't listed? Not even the new 400R boats are listed.
Change Manufacturer
>Select Year & Model
(2016 - 1994)
Power Boats
Note: Manufacturer note(s): No models produced from 2009 - 2011. The values represented are for boats with standard equipment. No further weight information available. N/A due to limited resale activity.
Model note(s): (*)Includes the value of the outboard motor(s). POWER BOATSLENGTHMODEL
TYPEHULLENGINE(S)HPWEIGHT
(LBS)BEAMFUEL
TYPESPECTRE SCF/CC(*)24'OUTBDFG122508'2"GasolineSPECTRE SCS/CC(*)24'OUTBDFG120008'2"GasolineSPECTRE 30 CAT-I/O30'PWRCTFG250008'9"GasolineSPECTRE 30 CAT-OB(*)30'PWRCTFG230008'9"GasolineSPECTRE 32 CS CAT-I/O32'PWRCTKV250009'GasolineSPECTRE 32 CS CAT-OB(*)32'PWRCTKV230009'GasolineSPECTRE 36 CAT/SP-I/O36'PWRCTKV2500010'2"Gasoline
>Select Year & Model
2005 Spectre-Pilini Values, Specs and Prices
Producing catamaran-hulled performance vessels, Spectre Powerboats entered the marine industry in 1994. Spectre Powerboats has created an assorted range of vessels from 15 to 42 feet in length. Offshore family cruising and even fishing is possible the products of Spectre Powerboats.Select a 2005 Spectre-Pilini Model
2016 2015 2014 2013 2012 2008 2007 2006 2005 2004 2003 2002 2001 2000 1999 1998 1997 1996 1995 1994(2016 - 1994)
Power Boats
(LBS)BEAMFUEL
Change Manufacturer
>Select Year & Model
(2016 - 1994)
Power Boats
(LBS)BEAMFUEL
TYPESPECTRE 30-OB(*)30'PWRCTFG KV225008'9"GasolineSPECTRE 32-I/O32'PWRCTFG KV252509'GasolineSPECTRE 32-OB(*)32'PWRCTFG KV325009'GasolineSPECTRE 36 PLEASURE-I/O36'PWRCTFG KV2525010'2"GasolineSPECTRE 36 POKER RUN-I/O36'PWRCTFG KV2525010'2"Gasoline
>Select Year & Model
2007 Spectre-Pilini Values, Specs and Prices
Producing catamaran-hulled performance vessels, Spectre Powerboats entered the marine industry in 1994. Spectre Powerboats has created an assorted range of vessels from 15 to 42 feet in length. Offshore family cruising and even fishing is possible the products of Spectre Powerboats.Select a 2007 Spectre-Pilini Model
Power Boats
(LBS)BEAMFUEL
Ah gotcha, yup, I see that how. I guess where I was having problems was with 2012 and newer, and not finding the 32's. And also, the 2008 and older don't have options for the Optimax XS motors.,whereas with Skater it does.
Either way, I've got my eye on a 28 Skater now. I'm gonna DM you about insurance.
