Go Back  Offshoreonly.com > Owners Forum > Spectre
5 blade props on 30' Spectre with 300XS's >
Old 02-08-2019 | 02:39 PM
Plum_Crazy's Avatar
The rev limiter is 6400 on the XS. I like to prop so I'm right at the limit in cool weather. This gives you the most RPM in all temps. You could talk to Dewald about tweaking those props one more time to get another 200 RPM. Not sure if it would help, though, as your prop slip is fantastic. I'm at 10%.
Plum_Crazy is offline
Old 09-26-2019 | 02:20 PM
Plum_Crazy's Avatar
Still loving the Dewald 5-blades. I bought Shaun Torrente's laser setup tool and started experimenting with propshaft height. I knew I was on the right track after going up to 1-5/8" and saw the best speed my wife and I have seen together. So, I tried 1-3/4" and got the boat out today by myself. Water pressure was still good at 15 psi and there was no difference in handling. It was a super calm day, but it recorded a new best top speed just a tick under 110. I know with some more chop, it will hit 110.
Old 07-12-2022 | 03:56 PM
I know this is old but awsome!!!!
skydog is offline
Old 03-19-2024 | 12:20 AM
I realise this is an old thread, however i was wondering how you set your engine heights, gearbox in relation to the bottom sponson. i have a 25foot victory cat with twin 300x and currently running 30x15 off shore cleavers and only getting around 97mph. i was thinking of ordering the 5 blade 30x15 dewalds. but also think my engine height is not where it should be?
000campbell is offline
Old 03-19-2024 | 07:14 AM
For top speed really as high as you can and still have good water psi. Normally the water psi is your limiting factor.
skydog is offline
Old 03-19-2024 | 09:56 AM
Plum_Crazy's Avatar
I bought the STR laser tool and set it up following these directions...
Old 10-14-2024 | 10:18 PM
How does a Spectre do in the loto slop? on flat water it seemed to hop some ..
ICDEDPPL is offline
Old 10-17-2024 | 11:32 AM
Plum_Crazy's Avatar
The Spectre hull is very trustworthy. I had it on LOTO with 4 people on a weekend and ran through some seriously snotty water without issue. It doesn't do anything weird. On the St. Croix River, I once missed seeing a big cruiser wake that came from the side and launched the boat in a way that it came down on one sponson. It just kept going straight. That being said, it's not a heavy hull and not a hull that slices through the waves. You mostly skip over them and can take a pounding in those conditions.
Yes, the 30 does have a hop. It varies, depending on setup. My old boat with twin 300X would start around 55 and continue to 75. I just avoided that range and would either cruise at 50 or 80.
