-   Sunsation (https://www.offshoreonly.com/forums/sunsation-43/)
-   -   From Mag to HO (https://www.offshoreonly.com/forums/sunsation/133295-mag-ho.html)
mess 06-20-2006 11:06 PM
From Mag to HO
I changed my 496 mag into a HO by replacing cam and Ecm. Increased speed from 65.5 GPS to 71.2 GPS. This is on a 2006 288 midcabin. Condtions were 60 degrees with 1ft. chop. Fresh water with two people on board weighing 475 pounds. Would like to here some numbers from other 288 midcabin owners. I should also say the motor has no other modifications. :D
tblrklakemo 06-25-2006 10:49 PM
Re: From Mag to HO
are you still running a stock bravo 1, or did you opt for a bravo X in your boat?
Mentalpause 06-26-2006 03:27 PM
Re: From Mag to HO
I bet you got more than 50 hp gain if you got almost 6 mph gain. :D
mess 06-26-2006 04:43 PM
Re: From Mag to HO
I am running the bravo one. I think your right about more than 50 hp gain. My thought was it would take CMI to get to 70mph with the cam and ECM change. Most posts I've read say 2 to 3 mph gain from Mag to HO. This was a great surprise. Not sure if Headers will do much more. What do you guys think?
sb30 06-30-2006 07:01 AM
Re: From Mag to HO
mess,
I am interested in doing the same conversion from mag to HO on my 04' 496 mag. Are the only things you need to change for the conversion the ECM and cam out of the HO? or are there any other little parts needed? And finally approximate costs of the parts? I can install myself.
Thank you,
SB30
mess 07-01-2006 08:04 PM
Re: From Mag to HO
Hey sb30,
New HO ECM & HO cam were the only changes I made to the motor. Purchased from BAM marine. ECM was around $1380 & cam was $419. I was very happy with the results.
30 outlaw 2005 07-03-2006 12:38 PM
Re: From Mag to HO
Did you do the install yourself or did you have someone else do it? Apox cost for install? I am putting on CMI on my Twin 496 Mags
sb30 07-06-2006 09:31 AM
Re: From Mag to HO
mess,
Thank you very much for the information. 2k for 50hp is not a bad deal so I think i will call BAM marine and do the same.
Thanks again,
SB30
mess 07-08-2006 09:33 PM
Re: From Mag to HO
30 Outlaw I used a authorized mercuriser dealer for the install.The cost was $1550 for installing the cam,ECM & full hydraulic steering. I could'nt believe it was that cheap.That's the first time I was surprised in a good way when it comes to paying a bill.
benztech 07-26-2006 12:01 PM
Re: From Mag to HO
mess, how many hrs were on the motor when you installed the ho cam? did you replace the cam bearings also? I have an '04 288 & am considering the mag to ho upgrade or going w/ the Raylar heads, cam & intake. did you check into reman ecu's? they are about half price.
