-   Sunsation (https://www.offshoreonly.com/forums/sunsation-43/)
-   -   Front Cleat / Bow Nav Light Access? (https://www.offshoreonly.com/forums/sunsation/338673-front-cleat-bow-nav-light-access.html)
Hateskate 01-11-2017 11:34 PM
Originally Posted by mlitefan2 (Post 4518265)
Great to speak with you today Jeff and appreciate the info!
What's the trick? Mine is a little loose and I was going to try and figure it out in the spring.
Jeff Sunsation 01-13-2017 06:20 AM
If you have a closed bow without the anchor locker, you will have to take down the 3 panels in the v-birth. Take the long, vinyl panels down, then the front vinyl "diamond" panel. Then you can access the cleat bolts. If you have an anchor locker, it's a little tricky. You have to access the bolts through there.
Hateskate 01-17-2017 04:24 PM
Thank you Jeff! Mine is a closed bow with no anchor locker. I was guessing this would be how to access it but now i'll put it on my list since I know how to tackle it.
