Go Back  Offshoreonly.com > Owners Forum > Sunsation
prop for 288 >
prop for 288
prop for 288
Old 09-25-2016 | 05:45 AM
Default prop for 288
what is the correct prop for a 2005 288 with 496 MAG HO ,fresh water use?
thank you
93 shooter is offline
Old 09-25-2016 | 10:15 AM
mlitefan2's Avatar
I ran a labed 24 B1 on my 288 but I have the older non stepped hull and a 502. I was running 69 @5200 - 5250 RPM at WOT. I touched 70 a few times but was into the trailer trim and playing with fire.
I thought I saw where some of the guys were running a 26 B1 with that setup? A labed 26 B1 would probably be a good fit. If you can get your hands on both, I would try them and see what feels best on the boat.
mlitefan2 is offline
Old 09-26-2016 | 06:28 AM
thank you for the reply,just purchased the boat and came with 26 B1 just wanted to make sure that was the correct prop
Old 09-26-2016 | 07:14 AM
26 pitch bravo one is what we run from the factory.
Jeff Sunsation is offline
Old 09-26-2016 | 07:39 AM
thank you
Old 09-26-2016 | 11:10 PM
I run a 28 p 4 blade labbed. 550 hp 502. 74 mph single stepped hull
BigPoppa05 is offline
Old 09-28-2016 | 01:57 PM
mlitefan2's Avatar
Anyone know what I should shoot for with 600HP on the older Hull? Not sure I can spin a 28 with that or not. Looking to be in the 55-5600RPM range WOT.
Old 09-28-2016 | 03:37 PM
I had about 575 HP and ran a labbed 28 Bravo from B Blades. Turned it 5,300 give or take.
SC288 is offline
Old 11-13-2016 | 10:43 PM
my 03 496 ho had a 24 on it. 26 on a mag seems like youd be leaving some rpms on the table imo...
THE 288 KID is offline
