Go Back  Offshoreonly.com > Owners Forum > Sunsation
Sink Drain/anchor locker drain? >
Old 12-19-2022 | 07:48 AM
Originally Posted by DrFeelgood
So is my older Dominator an oddball with a thru hull drain for the sink? #12 out of the mold, built in 1995.
In this picture it's at the lower right corner, a little difficult to see with the paint, right where orange meets black
I'm not too sure on those original ones. I started in 2002 and the boats produced from 2002-2005 had no thru hull drains for the sinks. The older original Dominators like yours had a different setup in the cabin and wetbar area so the sink might have been high enough to put the drain through the hull.
Jeff Sunsation is offline
Old 12-19-2022 | 07:53 AM
Veteran: Army
Ahh ok, makes sense. Thanks!
DrFeelgood is offline
Old 12-19-2022 | 09:24 AM
Originally Posted by moparjet
Mine doesn't have water tank or pump. Not sure why they even put a sink in there other than for looks
My understanding is, you can mortgage things with 'bathrooms' but that may not be accurate.
SabrToothSqrl is offline
Old 01-21-2023 | 06:49 PM
Should have a drain exit hole on the starboard side, pretty much directly near the sink. I just had to replace mine 02 288
AO12 is offline
