Originally Posted by Mentalpause
(Post 4647872)
Just my opinion, but I doubt it is engine weight, considering mine behaved the same way regardless of fuel load. But it consistently disliked being over trimmed no matter fuel or peeps load in the boat. Engines look awesome!:ernaehrung004:
they also built 6-7 single engine 32s also
and know 1 has good power and breaks 90 so doubt its stern weight issue prop and driving,,,,,,,,, straight bottom with pad likes a little flatter running to utilize the pad length now if u have the bow weighted down with lots of interior and supplies and boat tries to bow steer running little flatter then yes could be a cg problem to try adding transom weight or move weight out of bow as if was a bb from factory could be added weight in build up front all guessing but as stated gotta try bow lifting props with less trim 1rst |
Thought the 4 blades produced less bow lift than three blades. More blades more stern lift. What about drive hieght. Higher less bow lift .Or trying out hydromotive QlV ?? Someone must have a prop test option by you.
Try switching props so they turn out instead of in (looking at top edge of props) You just have to run shifters in reverse to go forward. It's free and takes little effort.. that will give less porpoise. Worked on my last boat. Had pad bottom 32ft. Not sure if you will loose top end if so not much
I didn't see mention of him turning in. Definitely want the props turning out on this hull.
I had a 32ft velocity. Drove like a bass boat. Always had the tabs just touching the water with little trim. Otherwise it would be airborne when first chance it had. Very loose. But reversing the props allowed tabs up and more trim. Had hydros on it
| All times are GMT -5. The time now is 11:27 AM. |
