-   Super Boat International (https://www.offshoreonly.com/forums/super-boat-international-191/)
-   -   P5 Question (https://www.offshoreonly.com/forums/super-boat-international/143469-p5-question.html)
Towsontown Auto 10-31-2006 06:16 AM
Re: P5 Question
FRANK,we just don't have a fast enough boat to step up to the plate ,but I do know of a boat that would give you a run for your money?or we could pull two spark plug wires off that crocket rocket?
used_parts 10-31-2006 07:11 AM
Re: P5 Question
Good luck Trent and Scott ,The P-5 Guys are truely real racers to accept you guys in thier class, I respect that alot, if you need any thing let Robert and I know.We will give you anything you need.I guess the F-1 class will be a easy win for someone.
James -Team Undecided 420
Bilgerat 10-31-2006 05:19 PM
Re: P5 Question
Is Used Parts running in P-4 team undecided? is that the velocity?
TGOR 10-31-2006 07:14 PM
Re: P5 Question
Originally Posted by Xtremeracing
Be easier if all the P5 teams stepped it up a notch and raced F1 , no need to worry about GPS.... :D
Frank,
In time...my current hull is too heavy to be competitive with a 500 EFI. Although, I understand Challenger is getting 90+ mph on the "improved" DDC-28 hull with a 600 SCi...and they're still dialing in the boat. :eek:
Sean
TGOR 10-31-2006 07:26 PM
Re: P5 Question
Originally Posted by Lauderdaleboats
I am also looking to run with P5 in the keys. I ran P3 with an A-Spec motor in Deerfield and blew the motor. I'll be dropping in a 500EFI for the worlds and estimate top speed to be in the low 70's. I am going to talk to SBI regarding boat length. I have the same hull as TGOR but canopied, my deck sweeps back over the drive though giving the boat an overall of 29'2".
Chris,
As Trent and I discussed about his boat, do the prop calc, run a legal set-up (max RPM, drive ratio, prop), and come race in P5. If you do have the same hull as ours, you should be good:
1.8. Hull and Deck Measurement Procedure
1.8.1. All race boats shall be measured to obtain a designated length on the centerline of the hull between the perpendiculars at the extreme bow and stern. All measurements will be taken while the boat is ashore. The keel line shall be level amidships. The stern shall be defined as the transom, joining the extremities of the hull on which the outboard motor or driveline is attached. Any extending parts, rub-rails, fenders, stabilizing and trim tabs, rudders or attached molded platforms are not to be included. Unless otherwise provided there is no length tolerance allowed in any class.
So your length should not include where your deck is swept back past the transom.
Sean
TGOR 10-31-2006 07:35 PM
Re: P5 Question
James,
We miss you guys...hope all is well.
Sean
Xtremeracing 10-31-2006 07:42 PM
Re: P5 Question
AL,
I like that Crockett Rocket ...Thats a new one :D :D :D
Xtremeracing 10-31-2006 07:45 PM
Re: P5 Question
James ,
You guys need to come out and have some fun again like u use to. Its been a while since we've seen you . Be well and hope to see u soon....
used_parts 11-01-2006 05:17 AM
Re: P5 Question
Thanks Guys ,Robert and I are working on a new program its called the ( no stress no more BS program ) were taking a break and doing some fishing and our company is cranking ,and yes we still own the Velocity and she still runs great and I miss you guys alot .But as you know I will never race SBI untill we truely have a even playing field in my eyes,as Im speaking for myself not Robert .My surgery went well and Im in the full recovery mode ,since Im a crazy Redneck I will be racing next year fulltime with a new setup motorwise with some help from my sponsors after I hold my GUN to thier head and tell them the gameplan!
Good Luck all my P Class friends and kick some azz.
James Glover Team Undecided 420 OPA
Kissimmee Fl. True Rednecks !!!
