Re: Steppbottom Bowlift
Originally Posted by z.zuperboat
So where does the quest end, and yes I also want my cake and eat it too.
Last year I wanted to go 70, this year I want to see 75+... Next Year??? :eek: |
How much longer before you see a motorized adjustable wing just behind the bow on the deck. Ultimate bow adjustability! I've seen it before but on a back yard project, it worked but everyone laughed. It's only a matter of time.
Originally Posted by Pat McPherson
Hi Bash,
Stormrider would gladly trade his shorter ones for yours if you believe your 280s are scrubbing speed... Personally, I think your better off with the larger tabs in rough water. Merc racing says the 150s are perfect for the 24 and the 280s would be too big. Pantera says I'll be fine w/ the 150s, but up to the 280s if I'm concerned. Would the longer tabs create more drag, decreasing speed more than the shorter ones? Just for the f of it, i'll post this topic in general disc. |
Bash what you say about breaking effect with k-planes makes a point. But every boat builder installs them so would not every V have the same problem ??? When we were on Maryland Y2K bow lift did not seem to be a problem at all. I guess I will see soon enough.
I prefer the longer ones cause they can lengthen your running surface and sometimes that is a good thing. Thats my preferance anyway. Great boarding platform as well. Too much though and it feels like your draging an anchor or two :eek: :eek:
OH not kidding K-Planes will double up as the boat ladder.
1 Attachment(s)
Would the longer tabs create more drag, decreasing speed more than the shorter ones? Sure if the longer plane is dragging even when up, it's going to slow you down. The fellow that owned my boat before me said that he liked the K-planes at neutral position for better stability when making speed runs. She had 500+HP and was running in the mid 80's for him though... |
O.K. Yes. All great answers! I'm with Z.ZUPERBOAT.
" I WANNNA EAT MY CAKE" Bowlift in Flat Water>GOOD Bowlift in Big Rough Water>BAD. I just dont see any benefit of the speed increase with the step. No natural lift & this thing needs lift to run. Period. I'd love to try the old style... with my setup. SUPER G- My concern is the k-planes on Stepbottoms...not all V's...The 24 & 30's seem to SQUAT in the water (this is not just coming from me by the way) so maybe the 280's are "hitting". BASH is gonna have to un-pin them for the old trial & error thing. :rolleyes: |
Is it possible that the 12 " setback has a negative effect in the rough at speed? The motor has to carry the weight further forward with such a set up. In calm not as much an issue cause more constant bite the motor has. Good idea to unpin the tabs..But I dont think thats gonna change things. I played with ny tabs I didnt feel any changes in performance in the first 1/4 or so of movement down from the full up position.
The step in the new 24' is a waste and likely does nothing good. When you trim her up to run fast the step is not even in the water. The other mods to the newer hull, bigger strakes, pad, and notch, do they help? Probably... Oh, buy the way, if anyone wants an older style hull to convert to OB, I'll strip mine at the end of the season... :drink: |
| All times are GMT -5. The time now is 04:39 AM. |
