-   Superboat (https://www.offshoreonly.com/forums/superboat-44/)
-   -   jackplate on a 24? (https://www.offshoreonly.com/forums/superboat/109980-jackplate-24-a.html)
FX10 08-15-2005 09:20 PM
Re: jackplate on a 24?
I think Superbash is running a 20". He's doing a solid 78 mph with a 300 Merc. And she rides beautiful !!
joneill 08-17-2005 08:16 PM
thanks guys for the info.
rch662 08-19-2005 09:17 AM
Hi Guys, i bought lightspeeds 24. it already has a 12" stainless marine set back plate. i asked if a plate would help and he said it's not worth the trouble. it's already set up great, which it is, the thing rocks and loves rough water. my question is if i mounted a plate (detwiler 6") to the stationary bracket what if any benefit would i see? (total 18" setback) also, even if i mounted it on the lowest bolt holes would i screw it up as to only jacking up. one more thing has anyone come up with a good fix for the front bolsters? when we get out in the good snot the bottoms drop out and momma don.t like that, it does make me laugh though. thanks Rick
FX10 08-19-2005 07:43 PM
RCH662,
Glad your having fun. As for the bolsters. I believe there's a spring clip that the bar fits into under the bottom of the seat. If it's popping out, try compressing the clip (hammer) a little. it might work. As for the setback, why play with it. What are we talking about ??? 1 MPH ???
SUPERSTITIOUS 08-19-2005 10:02 PM
From what I hear lightspeeds old (your new) 24 runs very respectibly as it is. Maybe leave well enough alone( thats also easy for someone else to say) :D
rch662 08-20-2005 06:29 AM
Good point, why screw with a good setup. the only reason i would consider it is to get the motor lower in the water for a better hole shot & if it would make it better to take the critters tubein. fx 10 i tried pinching the channels. also drilled out the end of the spring bars and put in cotter keys, no workey any other ideas? may be weld on some tabs and quick release pins? thanks Rick
SUPERSTITIOUS 08-21-2005 07:58 AM
Id go around and make sure all the bolts for all the mounting points are secure cause I found on mine a little wiggling from something being loose would cause an issue...Also check the hinge points. I like your idea of fashioning release pins
Pat McPherson 08-21-2005 12:47 PM
Superbash has done just about everything there is to do with his 24'.
12" setback, 18" setback, up, down, 250HP, 300HP, 3 blade, 4 blade...
He is the man to talk to... :drink:
joneill 08-24-2005 06:33 PM
what is a good bracket and jackplate to buy?
fastxxx 08-25-2005 06:54 AM
I have a 12" stainless marine set back (excellent condition) and a cmc 5 1/2 adjustable jackplate(brandnew never hit the water) both for $450.on long island in hampton bays.
