x factor on 24?
i am looking to set up an older 24, not sure on hp or x factor?
looking to do mid 80's, can you guys help? |
Re: x factor on 24?
looking to do mid 80's, can you guys help? She has Bravo 1 out-drive, Imco full hydraulic steering, and 280-K planes. Poweris a rebuilt 415HP/502MagMPI that probably makes 15-20HP more than stock. I run a 28p Bravo 1 prop with the engine topping out at 4800rpm. A three blade prop might make the boat go faster, but it is not as stable... Top speed recorded this year is 76.4mph GPS one person and low on fuel. With 4 people, gear, and 1/2 tank she tops out at 73-74mph. The previous owner of my boat had a 502 that was estimated at 550HP. I am not sure how fast the boat really went; the owner said he saw 89-90 on the speedo. My guess is low 80s. If you are re-rigging an older 24' with a Bravo 1 drive, I would start with the same X dim as mine, approx 17-1/2". Pantera also sets the X at 17-1/2" on their 24'. If you go higher, you will have to run one of the high $$ 5 or 6 blade props to carry the bow. 500HP will push the boat low 80s, 600HP might have a 24' knocking on 90. Full Hydraulic steering and K-280 size trim tabs are a must. I would also check the hull for any hook that may have developed over the years. If She is not straight, running above 70mph will be a chore... Good Luck and Please keep us posted. :drink: |
Re: x factor on 24?
I have a 1980 24' Superboat, basicly stock 454, with bolt on mods. TRS 23" 5 blade Ron Hill propeller, I go 71+ on GPS with 5 people and 1/2 tank gas. . No K-planes.
Re: x factor on 24?
Thayes11 give me a buz and let me know how the prop was and any interest in doing the ct river run ? 321-6767 Mike
Re: x factor on 24?
Mike, the best prop I tryed before this one was a 4 Blade Hydromotive, I have used Mirage plus, Bravo 1, The Ron Hill 5 blade has been the best to date, I gained few MPH top end, and 2-3 mph mid range... I will let you try it out and see how it works for your application - if your thinking about buying one. I will give you a call tomorrow. Tom
Re: x factor on 24?
thanks for the info Pat, it will be a big help to me.
| All times are GMT -5. The time now is 12:45 PM. |
