-   Superboat (https://www.offshoreonly.com/forums/superboat-44/)
-   -   24 x 7 Leaning?????? (https://www.offshoreonly.com/forums/superboat/304215-24-x-7-leaning.html)
FX10 11-07-2013 07:26 AM
Mitchie. To make your life easier. Make a template of the plate on the transom with the holes. Paper or 1/4" lauan would do. Beats holding up the K Plane to mark the holes. Your boat should look like Daves when it's done.
mitchie 11-07-2013 07:45 AM
I Learned that lesson the hard way already.... Its a ***** to get them straight without a template.
Dave M 11-09-2013 07:23 AM
I have a lot more pictures if you need them.
mitchie 11-09-2013 07:33 AM
Thanks for all the help.. I have them mounted. I'll post pics as soon as I can. I'm pumped to use them. The boat is going to need a transom soon though.. I've learned that. I also broke a fn' screw head off. Good thing there is nine more and 5200. I'll be pulling them off next semptember anyways to do the transom. I will do a much better job at round 2. This really frustrated me.
FX10 11-10-2013 06:08 AM
Don't use 5200 on the Tab plates. 5200 is an Adhesive. The bolts are holding the tabs on. 3m 4200, or 3M Marine Silicone. If you use 5200, when you attempt to remove them next September. Chances are you might rip off the gelcoat. Just sayin. Or use a lot of heat to soften the stuff.
mitchie 11-14-2013 02:11 PM
Here is the fruits of my labor. I cant wait to try them.
http://i42.tinypic.com/2qvxy4w.jpg
http://i40.tinypic.com/2v10nme.jpg
http://i43.tinypic.com/f4pb15.jpg
http://i39.tinypic.com/2vhw703.jpg
FX10 11-14-2013 08:37 PM
Do you have any pictures of them fully retracted?
OCCJoe 11-15-2013 07:05 AM
Mitchie I think you mounted your rams way too low. When they are retracted they should be 2-3" higher then the hull bottom. It looks like you just installed a set of aqua brakes.
mitchie 11-16-2013 01:51 PM
The pics are deceiving.... I put them as high as I could because of the stupid splashwell(you can see how close they are to the drains. When they are up all the way they are 2 and 1/4 above the bottom. When the transom is redone we will be doing a well delete. Then I will mount them higher. You can see by the straight edge where I'm at.
http://i41.tinypic.com/x39zr6.jpg
http://i44.tinypic.com/2lnakbq.jpg
http://i43.tinypic.com/2eyz6vs.jpg
http://i41.tinypic.com/snmcki.jpg
http://i41.tinypic.com/2958l1y.jpg
FX10 11-16-2013 05:50 PM
Right on the money Mitch.
