y2k prop slip >
y2k prop slip
y2k prop slip
Old 01-03-2015 | 03:48 PM
T-Mone's Avatar
T-Mone
Also if anyone has a external pick up on there y2k where did you install it?
T-Mone is offline
Old 01-04-2015 | 02:33 PM
Hey Ron you go out for a test run....
park35 is offline
Old 01-04-2015 | 07:14 PM
T-Mone's Avatar
T-Mone
Ok so i finally got out in between the fog .. I can def say i tried a -2 imco an it sucked! First run was w a 32 maximus w 15 5/8 dia. boat planed well but top end close to 95mph boats ass got loose had to back out of it at 5800. Next i tried the -2 w the 32 bravo that i used w my first run w stock lower which boat ran rt about 100. With the -2 boat only went 82 at 6000 rode like a bag of ****. So now im goin to my original set up w was my fastest set up w my other engine. Stock lower w a hydro p5 only thing is i need to get a 32 pitch.
T-Mone is offline
Old 01-05-2015 | 09:12 AM
Well sorry to hear that did not work out....a spacer might work better there are a few threads on this you might want to read
park35 is offline
Old 01-05-2015 | 10:49 AM
I started my new setup with a -2 Imco and my slip was 30% . The only time it came down was at wide open with a P5 on it . I ran 96 mph @5900 but in effort to not break the XR I've really have been trying to run Bravo's so I started throwing spacers on there, 1/2" then 1" and now 1 1/2" but still was running out of prop . Last time out was 104 @ 5900 pulling back .. I've got some more props in but winter sports have began so it will be spring before I finish my tuning .
Long story short , -2 doesn't work on my boat !
OCCJoe is offline
Old 01-05-2015 | 11:15 AM
You should call Brett at BBlades (or whoever you labbed it with) you are using the wrong numbers in your slip calculation for a "labbed" prop.
At 32 isnt a 32 (for prop slip calculation purposes) after it is labbed its considered more of a 31 or maybe even 30. After you use a more appropriate number you will see the slip numbers get more in check.
Keith Atlanta is offline
Old 01-05-2015 | 11:16 AM
What is in your boat for power at those speeds and rpm?
Shibby1485 is offline
Old 01-05-2015 | 12:16 PM
[QUOTE=Shibby1485;4244449]What is in your boat for power at those speeds and rpm?[/QUOTE
598ci big M, N/A around 800hp . Motor hasn't seen a dyno in seven years
OCCJoe is offline
Old 01-05-2015 | 02:17 PM
T-Mone's Avatar
T-Mone
104 an you backed out wow. Thats fast w 800hp. Steve you know i have over 900 so we def are still off w our numbers. plus i have the new design bottom. Well Steve looks like we will be out this weekend testing again! OCCJoe what pitch p5 did you run that u ran out of prop. I just got off the phone w Todd he is sending me a wheel now.
Ron.
T-Mone is offline
Old 01-05-2015 | 02:18 PM
T-Mone's Avatar
T-Mone
Joe give me a call i would like to talk some about set up 516-523-5852 Ron
T-Mone is offline
