-   Superboat (https://www.offshoreonly.com/forums/superboat-44/)
-   -   496 ho MODIFICATION (https://www.offshoreonly.com/forums/superboat/90052-496-ho-modification.html)
FX10 11-07-2004 07:50 PM
496 ho MODIFICATION
Keith,
I found the thread I was talking about.
http://www.offshoreonly.com/forums/s...ghlight=496+ho
Rick
krakmeup 11-07-2004 09:18 PM
Re: 496 ho MODIFICATION
Thanks Rick - printing this out for good reading material on the plane to LAX tomorrow - talk with you soon!
K
Pat McPherson 11-09-2004 02:52 PM
Hey Keith,
I recommend that you do not mess with the ECU. I have tried to have mine remapped three times and the stock calibration is the best.
All they do is raise the rev. limit and lean out the engine. You may gain 1-2mph up top but only if you modify your prop to gain the last 100rpm.
I would suggest that you run her stock until the warranty is up, then buy a set of those RTaylor aluminum heads...
FX10 11-11-2004 12:29 PM
Keith,
heres the whipple address
http://www.whipplesuperchargers.com/...sp?ProdID=1190
Rick
FX10 11-12-2004 04:42 PM
Keith,
Back to work. Had the cold from HELL !!! Talked to JC about the Whipple Stage 2. He thinks it's a good idea. Hell, 2 mph is 2 mph. With a light load of fuel and 1 person, you should hit 75. Doesn't 77 sound better ? ;)
Rick
jcap 11-12-2004 05:02 PM
I have also heard good things about the whipple stage 2 kit ,but keep in mind you can not go too far with hp with the 496. do a search, lots of threads on here re: 496 upgrades . Its a great 400 to 500 hp package but internals cant go higher and maintain reliability. When warrenty is up think 502 based package.
krakmeup 11-12-2004 05:12 PM
Or how about that V-10 Viper????? Hmmmmmmm............
jcap 11-13-2004 10:54 AM
Hey if you wanna get crazy, I was thinking surface drive with a GE Turbine! That should get me in triple digits!
SUPERSTITIOUS 11-13-2004 01:30 PM
Viper sounds great, just not alot of em around or mods yet. My dream Y2K is a hp 525 with the arnsen drive
FX10 12-11-2004 07:51 AM
I also found this
http://www.raylarengine.com/
