-   Sutphen (https://www.offshoreonly.com/forums/sutphen-64/)
-   -   Spring has Sprung (https://www.offshoreonly.com/forums/sutphen/101242-spring-has-sprung.html)
ChristianGott 04-20-2005 11:21 PM
Spring has Sprung
2 Attachment(s)
It's a balmy 79 here today and the boat came out of hibernation. Fired up perfectly and ready for a shake-down.
Who doesn't love New England in the spring? :drink: :drink: :D
C
no...there's not still snow on the ground!! :eek:
dave911 04-20-2005 11:38 PM
Re: Spring has Sprung
looking good....
dave911 04-26-2005 10:52 AM
Hey Christian!
While I'd be more interested in a twin OB Rum Runner, there's a Twin 350 Mag boat available in AZ (like yours).
Can you take a look at boat trader online?
What speed will she run? Will the Alphas hold up to more power? Is non-counter rotation an issue? She's got approx 300 hours.
Other comments?
Thanks!
ChristianGott 04-26-2005 07:46 PM
hey dave....
i bought my boat with somewhere over 300 hrs...it had a few minor issues (gimbal bearing/exhaust mani.s) but the motors are pretty bullet-proof, really durable. i cant answer your c/r question, spinning one the other direction must be more beneficial.....i've heard that you can simply switch the shift cable and prop..and run the drive in reverse...
i think that popular consensus for alphas is less than 400 horses, and small blocks only...no big blocks, too much torque...with my 4 blade revolution 23's i should be in the low to mid 70's...but i cruise at 3200 at 50ish, that's what i like.the revo's were designed to be a good ob prop, the hp of a small block sort of replicates the concept...
..that's the "airtime' boat, right?....looks pretty sweet...
careful with ob's i've heard stories of popped powerheads from being airborne, and thrown blades on set ups with older motors...if you search this thread, i think a guy out east here is looking to sell his ob boat....it looks pretty good, with newer motors..
good luck in your search...hope i helped.
c
dave911 04-27-2005 01:32 PM
Thanks for the scoop! Yep, it's the Airtime boat. Guy seems pretty cool. Second owner. Do you have a stereo mounted in your boat? Where? Airtime has none? Thanks!
floatingphil 04-27-2005 02:45 PM
My 1987 26 was a non counter-rotating boat and I converted it. Much better tracking and overall handling with the c/r setup, particularly in large waves but my handling woes were being compounded by sloppy drives. With Alphas you will have to find a complete c/r lower unit and swap it, change the cable location on the shifter, slap on a leftty and go!
These c/r units are scarce for Alpha I's so you will likely pay a lot.
Phil
ChristianGott 04-27-2005 10:59 PM
1 Attachment(s)
i have a stereo mounted inside the cabin door, over the built in cooler, but mounted in a box...like you would mount it outdoors, on a center console. it's like a hanging, free standing stack over the cooler, with the vhf attached below. yes the cooler is still functional, and i only had to make 2 screw holes to mount the whole thing....i hate cutting up a perfectly good boat!
it's out of the way looks neat and clean...i'll try to snap and post a pic tomorrow....thurs..or now...i zoomed and cropped,can you see it?
c
ChristianGott 04-28-2005 09:20 PM
1 Attachment(s)
d...
did the owner say non c/r? the pic looks like the props are turning out, counter rotating? anyone have thoughts?
c
floatingphil 04-29-2005 08:12 AM
I've stared at that photo a while now and my guess is they are both r/h props.
ChristianGott 04-29-2005 08:53 PM
1 Attachment(s)
somebody shoud ask for a better shot..i think they're rotaitng outward????? :confused: :confused: :confused:
i tried to zoom in...
floatingphil 04-30-2005 01:30 PM
sutphen30, We have a winner!
Time to trade in the old laptop for something with a better monitor.
dave911 04-30-2005 02:18 PM
OK. So what does this mean? Not Alpha 1's? Or can Alpha 1's be converted to Counter Roatation? Thanks!
floatingphil 05-01-2005 07:39 PM
dave911
Those are probably Alpha 1's vs the Alpha Gen II's and may have come from the factory as c/r or converted later depending upon the age of the boat. C/R Alpha I's appeared in about 1989.
dave911 05-01-2005 07:50 PM
Thanks all for the info! Boat is a '91.
