-   Sutphen (https://www.offshoreonly.com/forums/sutphen-64/)
-   -   Outrageous - speed with 420s? (https://www.offshoreonly.com/forums/sutphen/243359-outrageous-speed-420s.html)
dba900 12-01-2010 09:40 AM
Hi all,
I am most likely going to look at an Outrageous with crate 502s (about 415 hp each) and TRS drives. What should that boat run speed-wise? Is there much of a difference in the cockpit size between the Ocean Pacer and the Outrageous?
Thanks,
David
OL40SVX 12-01-2010 09:51 AM
More room in the outrageous. Which 33 is it?
shaun harrington 12-01-2010 01:44 PM
Originally Posted by dba900 (Post 3264422)
Hi all,
Thanks,
David
my 1987 33 wite trs and supposedly 500 hp would struggle to reach 70, i think the motors were closer to 400 hp. when tested new i believe a 33 with 420 reached 74. call richie or chris they will know for sure.
dba900 12-01-2010 02:03 PM
Hmm, sounds like 70 or so would be most likely. BTW, my father runs out of Falmouth Harbor; maybe we'll see you out there some time.
lucky strike 12-01-2010 03:31 PM
I have a friend with a 33 with 420's it runs 69mph
shaun harrington 12-01-2010 05:13 PM
what does your father run? falmouth is not noise friendly!:bsflag:
dba900 12-02-2010 09:30 AM
He's got a '78 Ocean Pacer with 330s :rolleyes: He hasn't done anything about mufflers yet, but we trailer the boat, so we can always drop it in elsewhere if we start getting hassled. I don't think they're doing too much enforcement these days, but of course things can always change.
Lucky Strike, thanks! That's about what I figured. Shaun, you must be right around 90 with twin 650s.
shaun harrington 12-02-2010 04:26 PM
right on the money 89.9 last time out but i was running with alot of fuel. and i had to trim the sh-- out of it , also i dont know what the props really are ,supposedly 30s , i hope for 92 93 with new props and more bow lift with less trim. we live in brewster and usually boat in cape cod bay . what color is your dads boat and where does he keep it?
dba900 12-03-2010 10:41 AM
It's a red Ocean Pacer named "Past Performance" :lolhit: He trailers it, but they live in Falmouth so we almost always launch out of Falmouth harbor. Good luck selecting the right prop - 92-93 is hauling the mail in the water we get on the Cape (as you well know)!
One more question: Would 500 hp a side get you to 80, or not quite? I have heard there's a cam upgrade you can do to the crate 502s in this boat I'm looking at that will net you around 500 hp.
OL40SVX 12-03-2010 12:07 PM
just buy TSUNAMI...it goes over 80!!!!
