Rum Runner Specs?
Anyone have the specs for the rum runner hulls? Weight, draft, width, etc?
Weight with a Single BBC? Would it sit higher in the water than a twin small block Rum Runner? I got about 3 - 3.5 feet of water where I can dock one. |
2 Attachment(s)
sometimes i sit in .5-1.5 and have to walk the freakin' thing out to 3 feet...:eek:
Originally Posted by ChristianGott
(Post 3517150)
The listed weight for an I/O hull is 4000 lbs... is that with engine and outdrive in place? I only ask because the O/B hull listed weight is 2800 lbs... so that has to be minus power. I highly doubt an unrigged I/O hull is going to be 1200 lbs heavier. |
the mud is really freakin' soft and I've disturbed a clam or two...3 feet would be a little slice of heaven for me....i figure, all told, I weigh in at 6000, boat, motors, fuel, trailer, gear, etc...a single 26 with the TRS set-up is going to be great...you should be very happy with the whole thing...
Which 26 single trs boat is it? Richie didn't build many at all.
| All times are GMT -5. The time now is 02:43 PM. |
