CMC PL-65 Transom Jack Plate >
Old 02-09-2010 | 02:17 PM
skater28's Avatar
Thumbs up CMC PL-65 Transom Jack Plate
Up for Sale : (2) CMC PL-65 Transom Jack Plate in excellent condition. This is the MANUAL PL-65 Weight: 32 lbs. Set Back : 5-1/2" Max Lift: 5" Dimensions are 18"W x 17-1/4"H. This jack was used for 300X heavy duty motors. In depth description below. Asking $350 for the set. Great deal. Any questions or curious to see pictures of the actual jacks instead of the stock photo e-mail me at [email protected]
CMC PL-65 Transom Jack Plate is a unique outboard motor hydraulic lifting device that works independently of your power trim and tilt to allow you to adjust your motor down while underway for better out-of-hole shots or up for more top-end speed and more prop clearance in shallow water. Made of tough, 1/2" aluminum alloy with stainless steel fasteners. These units are designed to fit all standard outboards and provide a 5-1/2" setback and 5" of vertical travel. Position-indicator gauge mounts in dash of boat for easy and safe determination of motor height. Sending unit is completely sealed and waterproof.
Maximum lift: 5".
WHAT I'm SELLING : CMC Manual Transom Jack is the same size and has the same features as the above model, but with a manual lift jack. Threaded shaft for easy height adjustment with wrench. Stock photo below
skater28 is offline
