Gimbal bearing red dot
In what year did Mer. put a red dot on there Ginbal bearing
The red dot indicates an XR bearing having a slight offset to provide clearance for the larger u - joint and yoke assy.The standard bearings have a black dot.
To answer your question ... I don't know for sure ... |
The new bearings have no color in the dot. They can be used for all drives. And you can not grease them. Like said above they came out with the X series of drives. I am going to guess around 2002. I can check a service buliten at home if you really have to know:drink:
| All times are GMT -5. The time now is 05:19 PM. |
