Spare Prop Holders
3 Attachment(s)
Set of two spare prop holders. Excellent working condition, some minor scuffing and wear. Stainless mounting hardware included.
$100 for the set plus shipping. $60 each plus shipping. |
Is the holder made for the prop to be stored without the hub? What are the made from....aluminum/stainless? Could you post a pic with a prop on it so I can see how it "locks" it down? Sorry for all the questions....I'll only need one...thanks.
1 Attachment(s)
Originally Posted by jdub
(Post 3151228)
The base is aluminum, the shaft is 3/4" diameter stainless steel. I can't post a pic with a prop on it because my props are on my boat at the moment, and it'll be at least a week before I could get to her, remove a prop and mount it on here. I did however disassemble it to give you an idea of the pieces and how the prop goes on. There's a rubber pad which rests at the bottom of the shaft on top of the base. Then you slide your prop on (with the hub included). On top of the prop hub goes the thicker rubber cushion, and then you screw down the triangle-looking wing nut until nice and snug. Then you insert the locking pin through the top. It fits bravo style props for certain, and may fit others that I'm not aware of. See pic. Hope this helps. |
Originally Posted by CigDaze
(Post 3151425)
No problem at all. Ask away. :)
I will take if not sold.
Steve |
OK...I see now. I'll take one.
(Post 3151425)
. :lolhit::party-smiley-004::coolcowboy: |
(Post 3151491)
I have a question....how the hell can you smoke Ultra lights???
Thanks for the interest everyone!
One is sold to member "jdub" (first reply), and the other one possibly to member "sonic" (first PM). Unless something changes, I will reply to everyone else in the order that I received inquiries. Thanks again. :) |
(Post 3151491)
| All times are GMT -5. The time now is 07:00 AM. |
