'86 272 Formula on Trailer
5 Attachment(s)
I have a 272 formula that im not going to finish. Id rather focus on my Cafe and get that back together and ready to run. Its bigger then I wanted as i was looking for a 24x7. The boat is almost dont but needs a few things
What has been done: Drive rebuilt New Trim Pistons- Both sides Bellows/Shifters/Gimbal Bearings- Both Sides SunPad Rear Seat recovered Cabing Door New Fuel Pumps Replaced-Holley Fuel Water Sep. New Spark Plugs- New Oil just changed Oil filter just replaced Also Just bought 23P Cleavers for it with new Hardware (lock washer nuts) Interior Arm Rest recoverd New Carpet and Step in cabin New Tires Wheel Bearings Seals Has to be done: Stbrd Thru Hull- Pull Motor, Take out Y Pipe, Replace with block off plate (i have it) Also have the Tips Finish recovering interior, I have the material for it. Set timing on engines Replace belts Set Shift points for drives, Alpha Set Shift cable distance Trim Tabs dont work but its all there Running lighst inop Docking lights inop Needs fuel sender wiring good Needs Temp sender for stb engine, pegged hot Need side windows in windshiled, Missing when i bought it Cabin door need to be put on, Missing hinges and Handle, New door i had cut is included I will deliever with in reason if needed just get a hold of me and we talk it over. Trailer was build to the boat not just an off the lot trailer in 97. All fresh water Winni Boat. Asking 9K OBO just want it out of my Cafe space. Thanks -Mike |
The boat is an LS and has small Block 350/260's. Should run in the low to mid 50's
-Mike |
Also has a full tank of 93 fuel and rebuild carbs. Its a 30th annevrsery edition
Nice,
Not ready to part with my 24x7 yet though:drink: |
Come On!!!!!!!!:evilb:
-Mike |
what do these typically sell for when complete?
12-15K. The Hull is in excellent shape. Front rollers just replaced on the trailer with Stolts non marking. I covered the port side couch seats last night. set the timing. I also mach'd up the sbt side exhaust. I have a set of risers coming so it will all be there. If i get to do it I do if not all parts are there to complete.
-Mike |
Replaced trim limiter switches and needed a coil so put a blaster 2 in it. Cutting exhaust holes tonight. Window templates are made just needs to be cut those go with it so ou can get a piece of glass cut. I have an extra 23P quicksilver prop ill throw in the boat along with everything else. Anyone with a 24x7 want to move up? It really only need small stuff to finish. A solid weekend it will be done. Ive had it out already. Runs good but need to be finished. Everything is there just needs to be finished.
-Mike |
Just dropped in 2 850 amp batts. interstate and cut the holes for the thru hull. I really dont want to pull the engine and put it in ive been working on the cafe and need this gone any reasonable offer its gone and help with del.
-Mike |
1 Attachment(s)
Interior seat just redone. here is a pic
-Mike |
| All times are GMT -5. The time now is 09:16 PM. |
