-   Swap Shop (https://www.offshoreonly.com/forums/swap-shop-253/)
-   -   M-1SC Procharger (https://www.offshoreonly.com/forums/swap-shop/239344-m-1sc-procharger.html)
eightsecmopar 11-17-2010 08:14 AM
Bump
eightsecmopar 11-26-2010 08:48 AM
Still available
FogduckerIII 11-26-2010 10:42 AM
Originally Posted by eightsecmopar (Post 3245938)
For EFI
This can actually be used for either, only difference is the intake connections......if it helps, I have the tubing and full intake cover for a carb set-up..... I bought a used M-1SC unit that was for a BBC carb set-up and installing it on an EFI application so there are extra parts. Procharger can supply any additional items needed but be aware, you have to ask them the right questions and do your research....just saying.....
Good luck with the sale.
85Baja 11-26-2010 10:56 PM
Would this be able to be mounted for a 502 efi? What additional things do i need to purchase to make it work and what do you think it would cost?
eightsecmopar 11-27-2010 05:51 AM
I would give Procharger a call. I would think only the mounting brackets
craigdskilling 11-28-2010 08:52 AM
Is a procharger only good on a stock motor.I have a383 stroker carb 750 pushing 400+hp woud this give me any more.thanks craig
eightsecmopar 11-28-2010 09:32 AM
Yes you can use a Procharger on any engine. If you go to the Procharger website I think they had some examples listed of the power gains and not all of them were stock. I think bolting on this system with you all ready making 400hp, you would probably be around 600-650 hp. Maybe a little more because of the inter-cooler. You can give Procharger a call and talk to them they would be able to give you more accurate specs.
lightning jet 11-28-2010 09:35 AM
I ran a m3sc on a carb 572.when it worked it was big power ..............just not consistant
pachanga 11-28-2010 10:09 AM
I would think you are running a pretty high compression ratio with that power. Remember any forced induction raises compression. The slightest hiccup(lean situation or detonation) with high compression and I expect your motor will go BOOM!
craigdskilling 11-28-2010 03:45 PM
what do you mean constant power does a charger have at top or all around.do you think it would put out that much.thats alot of power.
