BBC Roller cam cams lifters ect.
I have two complete Roller cam shaft sets. BBC 500hp carbed
replacement cams. Everything X2
Billet cams 500 hp replacements. (No Numbers)
Bronze gears
Roller lifters
True roller chain and gears.
Timing covers and timing tabs
Cam plates with the machine bolts.
Valve springs
Retainers and locks.
All out of a good running engine.
$1000.00 + shipping. Can take phone payment.
Thanks,Timmy Farmer .270 575-0204
270 331-0695
Bronze gears
Roller lifters
Valve springs
270 331-0695
Yes they will fit 4,5 and6 gen. I am including the block plates and screws with them. Just tap your block if its not already done. I like to do that to all my bbc engines this way because you dont have to worry about the cam buttons comming apart and killing your engine. This stuff is all good and dirt cheap!
I dont have a gen-6 block here to test them with.
My gen 4 Dart blocks have to have a .400 tall lifter because of the tie bar design. There is 100s of different manufactures out there.
have no idea on the hours. The engines were very clean. Nothing at all was broken. All the bearings were good. No numbers that can be identified
Most of the marine companies are secrective about there grinds and wont put the specs on there cams like the automotive industry. All I know is they are hp 500 replacements. Carb engines.
Im not sure on the hours. Nothing looks abused at all but I
