Some misc stuff. Fuel pumps, XR hub, etc
1 Holley 130GPH marine mechanical pump. 1/2NPT inlet and outlet...used but works fine. 45.00
1 Holley 120GPH marine mechanical pump. 1/2NPT inlet and outlet. Used but works fine. 35.00
1 Bravo XR hub insert. Just the insert. 50.00
1 Floor mount trim pump bracket for bravo style pump. 25.00
1 pair of gaffrig performance series air activated mufflers. Never ran. they fit 3" tips. I repeat 3 Inch...But really nice looking mufflers! 100 bucks for the pair. They come with the air cylinders. No pump.
Pair of used Motorola Merc alternators. These are the 3 wire ones. 55amp I think. Work fine. 50.00 ea.
2 TRS tailstocks. Both have good bearing and seal in them. 100 each.
2 pairs of ssm style transmission mounts. They mount to the transmission and then inner transom plate on a SSM III, IIIA, or V setup. So no need for rear raceplate. 100 per pair.
